Hi!
We have egroupware 1.2xx in use and now I’m planning to upgrade it to 1.6.
Can I do it directly or should I upgrade to 1.4 first.
We use mail, calendar, syncml and resources only.
Hi!
Ok, I tried upgrade directly from 1.2 to 1.6 but it didn’t work.
What went wrong?
Do we have to upgrade 1.4 then 1.6 ?
can’t we just restore 1.2’s backup to 1.6 ?
any idea?
Yes I made it by uprading first to 1.4 and then 1.6
and it works
Thank you, for replying.
But if i take backup of pgsql DB with pgadmin3 like tool of egw.1.2 and then
remove egw 1.2 ,
install egw 1.6 &
restore that backup. Will that work?
and it works shripatel:What went wrong?
any idea?
ad-ht:Ok, I tried upgrade directly from 1.2 to 1.6 but it didn’t work.
Hi!
Database structure has changed quite a lot so I believe it doesn’t work
regards
Hannu
remove egw 1.2 ,
install egw 1.6 &
restore that backup. Will that work? ad-ht:Yes I made it by uprading first to 1.4 and then 1.6
any idea?
