When adding new units of measure, I ran into a problem whereby the existing unit names (each, pound, feet etc) seem to be erased, although the the row entries appear to still exist. So if I have a list like:
- Each
- Inch
- CM
- Pound
- KG
and I add
- Feet
- Hours
I end up with
- Hours
This seems to happen after adding a second new item, not just one. I’m not sure I’ve isolated the exact scenario yet. The image below is after deleting every item and starting a new list from scratch.
Ron
existing
the row
Good catch, it was clearing the name. You’re supposed to be able to
edit those…
Fixed in rev. 2902
Nathan Gray
nathan at goarctic dot com
It is the best place to buy or sell services for
http://p.sf.net/sfu/Xq1LFB
Perp-developers mailing list
Perp-developers@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/perp-developers
