Sudden performance decrease
Hi all
I have been encountering a significant performance degradation with EGW in the last 24hrs. The only system or global setting I directly changed was some email server connection information, but now all of the modules are very slow in responding to selections (ie clicking on Calendar or Resources leads to a very long wait, often minutes, before the module loads.
I have checked the underlying server (ClaerOS) and there is plenty of RAM available, and no process is consuming the CPU, and there is no disk-swapping occurring. Other services and applications on the underlying OS are performing normally.
The EGW logs are not showing any errors, and I don’t know if there is any performance logging in the EGW utility set. I do not know how to check performance on the underlying MySQL d/b.
Any pointers greatly appreciated
regards
Ken
Hi all
As a follow-on to the previous post, it seems that EGW is performing normally when accessing modules UNTIL I try to access Felamimail. This module is no longer loads, it merely stays with hourglass icon and no activity.
Any attempts to load other modules AFTER trying email also fail. I have to close the browser window, then re-connect & login to be able to access any of the modules.
This is the Email server profile list:
Description - global
SMTP server name - 142.25.56.13
imap server name - 142.25.56.13
Application - Any application
Group - Any group
User - any user
Active - Active
This behavior seems to have started shortly after I tried to configure the ability for a user to access an IMAP account that was not the same username/password as the EGW account.
regards
Ken
Hi all
regards
Ken
10 Tips for Better Web Security
Learn 10 ways to better secure your business today. Topics covered include:
Web security, SSL, hacker attacks & Denial of Service (DoS), private keys,
security Microsoft Exchange, secure Instant Messaging, and much more.
http://www.accelacomm.com/jaw/sfnl/114/51426210/
Hi all
Any attempts to load other modules AFTER trying email also fail. I have to close the browser window, then re-connect & login to be able to access any of the modules. If I do not try to load Felamimail, but just try to go to the email preferences, there is a very long wait before the page loads (over 1 min).
Group - Any group
User - any user
Active - Active
Email is a key application here, and my push to have EGW as the groupware solution for our whole organisation is at risk if I cannot get this sorted. Right now, while other modules are accessible, the moment I try email, all modules become inaccessible.
I am not a programmer or even very good with scripting like php, so I don’t even know where to start looking. The server host logs don’t show any errors (that I can find) related to php, eGroupware, of failed connections. The Email server has not experienced any issues, and staff are sending & receiving fine with their own clients, such as Thunderbird.
All I need is a quick & dirty fix; is it possible to uninstall & re-install just Felamimail? Is there a chance this would fix the problem?
regards
Ken
Hi all
regards
Ken
5 Ways to Improve & Secure Unified Communications
Unified Communications promises greater efficiencies for business. UC can
improve internal communications as well as offer faster, more efficient ways
to interact with customers and streamline customer service. Learn more!
http://www.accelacomm.com/jaw/sfnl/114/51426253/
Hi Kenneth!
Which egw version do you use? I experienced felamimail to take a pretty
long time to load an imap inbox after an update 1.6 -> 1.8 But after
this initial felamimail delay everything works again. I use nonencrypted
imap on localhost.
regards
Hi all
Group - Any group
User - any user
Active - Active
regards
Ken
To: "egroupware-users@lists.sourceforge.net" egroupware-users@lists.sourceforge.net
Sent: Wednesday, July 20, 2011 1:19:59 PM
Subject: [eGroupWare-users] sudden performance decrease
Hi all
regards
Ken
Hi
We are using 1.8, and all was good for months, up until I tried to allow users to set different email accounts. I also am unencrypted IMAP, but connecting to remote host
On my home page, I now see this: (need to view this email in html, not plain text)
eMail
can’t connect to INBOX!!
With my email server profile set as below, as I understand it, my EGW login credentials should be applied in communicating with the server and accessing IMAP. That is how it WAS working before.
regards
Ken
Hello all
Update on this issue:
I was able to salvage our working EGW install - I collected email server information from an older Virtual Machine image I had used before going live (backups WORK!)
Sorry to bother everyone. This was a self-inflicted problem from incorrect settings.
regards
Ken
Hi Kenneth!
imap on localhost.
regards
Hi all
Group - Any group
User - any user
Active - Active
regards
Ken
Hi all
regards
Ken
