Author: nathangray
New Revision: 54875
URL: http://svn.stylite.de/viewvc/egroupware?rev=54875&view=rev
- Change all day event sorting so longer events are higher
- Change short event display so 1 line shows title, 2-4 lines show timespan & title
- Increase maximum number of events loaded at once
trunk/calendar/js/app.js
trunk/calendar/js/et2_widget_daycol.js
trunk/calendar/js/et2_widget_event.js
trunk/calendar/templates/default/app.css
Modified: trunk/calendar/js/app.js
URL: http://svn.stylite.de/viewvc/egroupware/trunk/calendar/js/app.js?rev=54875&r1=54874&r2=54875&view=diff
— trunk/calendar/js/app.js (original)
+++ trunk/calendar/js/app.js Thu Jan 28 22:35:22 2016
@@ -2713,7 +2713,7 @@
this.egw.dataFetch(
instance ? instance.etemplate_exec_id :
this.sidebox_et2.getInstanceManager().etemplate_exec_id,
{start: start, num_rows:200},
{start: start, num_rows:400}, query, this.id, function calendar_handleResponse(data) {
Modified: trunk/calendar/js/et2_widget_daycol.js
URL: http://svn.stylite.de/viewvc/egroupware/trunk/calendar/js/et2_widget_daycol.js?rev=54875&r1=54874&r2=54875&view=diff
— trunk/calendar/js/et2_widget_daycol.js (original)
+++ trunk/calendar/js/et2_widget_daycol.js Thu Jan 28 22:35:22 2016
@@ -737,11 +737,15 @@
this._children.sort(function(a,b) {
var start = new Date(a.options.value.start) - new Date(b.options.value.start);
var end = new Date(a.options.value.end) - new Date(b.options.value.end);
// Whole day events sorted by ID, normal events by start / end time
if(a.options.value.whole_day && b.options.value.whole_day)
return (a.options.value.app_id - b.options.value.app_id);
// Longer duration comes first so we have nicer bars across the top -
var duration = -
(new Date(b.options.value.end) - new Date(b.options.value.start)) - -
(new Date(a.options.value.end) - new Date(a.options.value.start)); -
return duration ? duration : (a.options.value.app_id - b.options.value.app_id); } else if (a.options.value.whole_day || b.options.value.whole_day) {
@@ -890,7 +894,7 @@
columns[c][i].div.css(‘left’, left.toFixed(1)+’%’);
columns[c][i].div.css(‘right’, right.toFixed(1)+’%’);
columns[c][i].div.css(‘z-index’,parseInt(20)+c);
columns[c][i]._small_size(); } } // Only wanted to position this event, leave the other columns alone
Modified: trunk/calendar/js/et2_widget_event.js
URL: http://svn.stylite.de/viewvc/egroupware/trunk/calendar/js/et2_widget_event.js?rev=54875&r1=54874&r2=54875&view=diff
— trunk/calendar/js/et2_widget_event.js (original)
+++ trunk/calendar/js/et2_widget_event.js Thu Jan 28 22:35:22 2016
@@ -281,6 +281,7 @@
.removeClass(function(index, css) {
return (css.match(/calendar_calEvent\S+/g) || []).join(’ ');
.removeClass('calendar_calEventSmall') .addClass(event.class) .toggleClass('calendar_calEventPrivate', typeof event.private !== 'undefined' && event.private); this.options.class = event.class;
@@ -304,16 +305,13 @@
// Header
var title = !event.is_private ? event['title'] : egw.lang('private');
// If there isn't enough height for header + 1 line in the body, it's small -
var small_height = this.div.innerHeight() <= this.title.height() * 2; -
if(!this.title.height()) -
// Handle sizing while hidden, such as when calendar is not the active tab -
small_height = egw.getHiddenDimensions(this.div).h < egw.getHiddenDimensions(this.title).h * 2 -
this.div.attr('data-title', title); -
this.title.text(small_height ? title : this._get_timespan(event));
// Height specific section -
this._small_size(); -
this.title -
.html('<span class="calendar_calTimespan">'+this._get_timespan(event) + '<br /></span>') -
.append('<span class="calendar_calEventTitle">'+title+'</span>') // Colors - don't make them transparent if there is no color if(jQuery.Color("rgba(0,0,0,0)").toRgbaString() != jQuery.Color(this.div,'background-color').toRgbaString())
@@ -351,6 +349,31 @@
- Calculate display variants for when event is too short for full display
- Display is based on the number of visible lines, calculated off the header
- height:
- 1 - show just the event title, with ellipsis
- 2 - Show timespan and title, with ellipsis
4 - Show description as well, truncated to fit
- _small_size: function() {
this.div.removeClass('calendar_calEventSmall'); -
if(this.options.value.whole_day_on_top) return; -
var visible_lines = Math.floor(this.div.innerHeight() / this.title.height()); -
visible_lines = Math.floor(egw.getHiddenDimensions(this.div).h / egw.getHiddenDimensions(this.title).h); -
this.div.toggleClass('calendar_calEventSmall',visible_lines < 4); -
this.div -
.attr('data-visible_lines', visible_lines < 4 ? Math.max(1,visible_lines) : ''); - },
- Examines the participants & returns CSS classname for status
@returns {String}
@@ -424,7 +447,7 @@
'<span class="calendar_calEventTitle">'+this.div.attr('data-title')+'</span><br>'+
'<span class="calendar_calEventTitle">'+this.options.value.title+'</span><br>'+ this.options.value.description+'</p>'+ '<p style="margin: 2px 0px;">'+times+'</p>'+ (this.options.value.location ? '<p><span class="calendar_calEventLabel">'+this.egw().lang('Location') + '</span>:' + this.options.value.location+'</p>' : '')+
Modified: trunk/calendar/templates/default/app.css
URL: http://svn.stylite.de/viewvc/egroupware/trunk/calendar/templates/default/app.css?rev=54875&r1=54874&r2=54875&view=diff— trunk/calendar/templates/default/app.css (original)
+++ trunk/calendar/templates/default/app.css Thu Jan 28 22:35:22 2016
@@ -619,6 +619,9 @@
background-color: rgba(255,255,255,0.9);
+.calendar_calEventHeader .calendar_calEventTitle {- display: none;
.calendar_calEventHeaderSmall{
font-size: 8pt;
line-height: 10pt;
@@ -663,6 +666,31 @@
.calendar_calEventTitle{
font-weight: bold;
+/* Event is too small for full display */
+.calendar_calTimeGrid:not(.calendar_calTimeGridList)
+.calendar_calEventSmall[data-visible_lines=‘1’] .calendar_calTimespan {- display: none;
+.calendar_calEventSmall[data-visible_lines=‘2’] .calendar_calTimespan,
+.calendar_calEventSmall[data-visible_lines=‘3’] .calendar_calTimespan { - display: inline;
+.calendar_calEventSmall[data-visible_lines=‘1’] .calendar_calEventTitle,
+.calendar_calEventSmall[data-visible_lines=‘2’] .calendar_calEventTitle,
+.calendar_calEventSmall[data-visible_lines=‘3’] .calendar_calEventTitle {- display: inline;
+.calendar_calEventSmall .calendar_calEventBody { - padding-top: 2em;
/* Events as displayed in a list, not sized by time */
Modified: trunk/calendar/templates/pixelegg/app.css
URL: http://svn.stylite.de/viewvc/egroupware/trunk/calendar/templates/pixelegg/app.css?rev=54875&r1=54874&r2=54875&view=diff— trunk/calendar/templates/pixelegg/app.css (original)
+++ trunk/calendar/templates/pixelegg/app.css Thu Jan 28 22:35:22 2016
@@ -618,6 +618,9 @@
background-color: rgba(255, 255, 255, 0.9);
.calendar_calEventHeaderSmall {
font-size: 8pt;
line-height: 10pt;
@@ -662,6 +665,22 @@
font-weight: bold;
+.calendar_calTimeGrid:not(.calendar_calTimeGridList) .calendar_calEventSmall[data-visible_lines=‘1’] .calendar_calTimespan { - display: none;
+.calendar_calTimeGrid:not(.calendar_calTimeGridList) .calendar_calEventSmall[data-visible_lines=‘2’] .calendar_calTimespan,
+.calendar_calTimeGrid:not(.calendar_calTimeGridList) .calendar_calEventSmall[data-visible_lines=‘3’] .calendar_calTimespan { - display: inline;
+.calendar_calTimeGrid:not(.calendar_calTimeGridList) .calendar_calEventSmall[data-visible_lines=‘1’] .calendar_calEventTitle,
+.calendar_calTimeGrid:not(.calendar_calTimeGridList) .calendar_calEventSmall[data-visible_lines=‘2’] .calendar_calEventTitle,
+.calendar_calTimeGrid:not(.calendar_calTimeGridList) .calendar_calEventSmall[data-visible_lines=‘3’] .calendar_calEventTitle { - display: inline;
+.calendar_calTimeGrid:not(.calendar_calTimeGridList) .calendar_calEventSmall .calendar_calEventBody { - padding-top: 2em;
.calendar_calTimeGridList .calendar_calTimeGridScroll {
http://pubads.g.doubleclick.net/gampad/clk?id=267308311&iu=/4140
eGroupWare-cvs mailing list
https://lists.sourceforge.net/lists/listinfo/egroupware-cvs -
