R53524 - in /trunk/etemplate: inc/ js/ templates/default/
Author: nathangray
New Revision: 53524
URL: http://svn.stylite.de/viewvc/egroupware?rev=53524&view=rev
Fix vfsUpload widget did not display its value
trunk/etemplate/inc/class.etemplate_widget_vfs.inc.php
trunk/etemplate/js/et2_widget_vfs.js
trunk/etemplate/js/etemplate2.js
trunk/etemplate/templates/default/etemplate2.css
Modified: trunk/etemplate/inc/class.etemplate_widget_vfs.inc.php
URL: http://svn.stylite.de/viewvc/egroupware/trunk/etemplate/inc/class.etemplate_widget_vfs.inc.php?rev=53524&r1=53523&r2=53524&view=diff
— trunk/etemplate/inc/class.etemplate_widget_vfs.inc.php (original)
+++ trunk/etemplate/inc/class.etemplate_widget_vfs.inc.php Tue Sep 1 00:32:50 2015
@@ -55,7 +55,11 @@
// Single file, already existing
if (substr($path,-1) != ‘/’ && egw_vfs::file_exists($path) && !egw_vfs::is_dir($path))
  •   			$value = $path;
  •   			$file = egw_vfs::stat($path);
  •   			$file['path'] = egw_vfs::resolve_url($path);
  •   			$file['name'] = egw_vfs::basename($file['path']);
  •   			$file['mime'] = egw_vfs::mime_content_type($file['path']);
  •   			$value = array($file);
      		else if (substr($path, -1) == '/' && egw_vfs::is_dir($path))
@@ -63,6 +67,9 @@
foreach($value as &$file)
$file = egw_vfs::stat("$path$file");
  •   				$file['path'] = $file['url'];
@@ -73,7 +80,7 @@
parent::ajax_upload();
foreach($_FILES as $field => $file)
  •   	self::store_file($field, $file);
  •   	self::store_file($_REQUEST['widget_id'], $file);
@@ -134,7 +141,7 @@
* $content array and the application should deal with the file.
public static function store_file($path, $file) {
  •   $name = $path;
  •   $name = $_REQUEST['widget_id'];
      // Find real path
      if($path[0] != '/')
Modified: trunk/etemplate/js/et2_widget_vfs.js
URL: http://svn.stylite.de/viewvc/egroupware/trunk/etemplate/js/et2_widget_vfs.js?rev=53524&r1=53523&r2=53524&view=diff
— trunk/etemplate/js/et2_widget_vfs.js (original)
+++ trunk/etemplate/js/et2_widget_vfs.js Tue Sep 1 00:32:50 2015
@@ -642,10 +642,15 @@
var et2_vfsUpload = et2_file.extend(
  • attributes: {
  •   "value": {
  •   	"type": "any",	// Either nothing, or an object with file info
    legacyOptions: [“mime”],
    asyncOptions: {
  •   url: egw.ajaxUrl("etemplate_widget_vfs::ajax_upload::etemplate")
  •   target: egw.ajaxUrl(self.egw().getAppName()+".etemplate_widget_vfs.ajax_upload.etemplate")
    @@ -657,16 +662,64 @@
    init: function(_parent, attrs) {
    this._super.apply(this, arguments);
  •   this.input.addClass("et2_vfs");
  •   $j(this.node).addClass("et2_vfs");
      // If the ID is a directory, allow multiple uploads
      if(this.options.id.substr(-1) == '/')
      	this.set_multiple(true);
  •   this.list = $j(document.createElement('table')).appendTo(this.node);
    • If there is a file / files in the specified location, display them
    • @param {Object[]} _value
    set_value: function(_value) {
  •   this.progress.empty();
  •   this.list.empty();
  •   for(var i = 0; i < _value.length; i++)
  •   	this._addFile(_value[i]);
  • getDOMNode: function(sender) {
  •   if(sender !== this && sender._type.indexOf('vfs') >= 0 )
  •   	var value = sender.getValue && sender.getValue() || sender.options.value || {};
  •   	var row =  $j('[data-path="'+(value.path)+'"]',this.list);
  •   	if(sender._type === 'vfs-mime')
  •   		return $j('.icon',row).get(0) || null;
  •   	else
  •   		return $j('.title',row).get(0) || null;
  •   else
  •   	return this._super.apply(this, arguments);
  • _addFile: function(file_data) {
  •   var row = $j(document.createElement("tr"))
  •   	.attr("data-path", file_data.url)
  •   	.attr("draggable", "true")
  •   	.appendTo(this.list);
  •   var mime = $j(document.createElement("td"))
  •   	.addClass('icon')
  •   	.appendTo(row);
  •   var title = $j(document.createElement("td"))
  •   	.addClass('title')
  •   	.appendTo(row);
  •   var mime = et2_createWidget('vfs-mime',{value: file_data},this);
  •   var vfs = et2_createWidget('vfs', {value: file_data}, this);
    et2_register_widget(et2_vfsUpload, [“vfs-upload”]);
Modified: trunk/etemplate/js/etemplate2.js
URL: http://svn.stylite.de/viewvc/egroupware/trunk/etemplate/js/etemplate2.js?rev=53524&r1=53523&r2=53524&view=diff
— trunk/etemplate/js/etemplate2.js (original)
+++ trunk/etemplate/js/etemplate2.js Tue Sep 1 00:32:50 2015
@@ -469,7 +469,7 @@
// Insert the document fragment to the DOM Container
this.DOMContainer.appendChild(frag);
  •   	if(egw.debug_level >= 3 && console.groupEnd)
  •   	if(egw.debug_level() >= 3 && console.groupEnd)
      		egw.window.console.groupEnd();
Modified: trunk/etemplate/templates/default/etemplate2.css
URL: http://svn.stylite.de/viewvc/egroupware/trunk/etemplate/templates/default/etemplate2.css?rev=53524&r1=53523&r2=53524&view=diff
— trunk/etemplate/templates/default/etemplate2.css (original)
+++ trunk/etemplate/templates/default/etemplate2.css Tue Sep 1 00:32:50 2015
@@ -864,6 +864,14 @@
.et2_vfs li.vfsFilename:not(:last-child):after {
padding: 0.25ex;
+.et2_vfs table {
  • width: 100%;
  • max-height: 6em;
  • overflow: auto;
    +.et2_vfs td.icon {
  • width: 16px;
    button.et2_vfs_btn {
    margin: 0;
eGroupWare-cvs mailing list
