Author: ralfbecker
New Revision: 53376
URL: http://svn.stylite.de/viewvc/egroupware?rev=53376&view=rev
- Admin: fix SQL error when searching in access rights popup (probably other places too)
trunk/etemplate/inc/class.so_sql.inc.php
Modified: trunk/etemplate/inc/class.so_sql.inc.php
URL: http://svn.stylite.de/viewvc/egroupware/trunk/etemplate/inc/class.so_sql.inc.php?rev=53376&r1=53375&r2=53376&view=diff
— trunk/etemplate/inc/class.so_sql.inc.php (original)
+++ trunk/etemplate/inc/class.so_sql.inc.php Thu Aug 13 14:55:01 2015
@@ -1230,10 +1230,6 @@
$search_cols = $this->get_default_search_columns();
if(!$search_cols) -
return array(); -
} // Concat all fields to be searched together, so the conditions operate across the whole record foreach($search_cols as $col) {
@@ -1249,15 +1245,15 @@
$numeric_columns[] = $col;
continue;
if ($this->db->Type == 'mysql' && $table_def['fd'][$col_name]['type'] === 'ascii' && !preg_match('/[\x80-\xFF]/', $_pattern))
if ($this->db->Type == 'mysql' && $table_def['fd'][$col_name]['type'] === 'ascii' && preg_match('/[\x80-\xFF]/', $_pattern)) { continue; // will only give sql error } $columns[] = sprintf($this->db->capabilities[egw_db::CAPABILITY_CAST_AS_VARCHAR],"COALESCE($col,'')"); }
if($columns) -
$columns = call_user_func_array(array($GLOBALS['egw']->db,'concat'),$columns);
if(!$search_cols) -
return array(); } // Break the search string into tokens
@@ -1317,7 +1313,8 @@
$op = ‘OR’;
break;
$token_filter = " $columns " . $this->db->capabilities['case_insensitive_like'] . ' ' .
$token_filter = ' '.call_user_func_array(array($GLOBALS['egw']->db,'concat'),$columns).' '. -
$this->db->capabilities['case_insensitive_like'] . ' ' . $GLOBALS['egw']->db->quote($wildcard.str_replace(array('%','_','*','?'),array('\\%','\\_','%','_'),$token).$wildcard); // Compare numeric token as equality for numeric columns
eGroupWare-cvs mailing list
