R51649 - in /trunk/etemplate: js/et2_extension_nextmatch.js templates/default/etemplate2.css
Author: nathangray
New Revision: 51649
URL: http://svn.stylite.de/viewvc/egroupware?rev=51649&view=rev
Nextmatch print styling
  • Hide nextmatch header
  • Change styling of selectboxes in row header
trunk/etemplate/js/et2_extension_nextmatch.js
trunk/etemplate/templates/default/etemplate2.css
Modified: trunk/etemplate/js/et2_extension_nextmatch.js
URL: http://svn.stylite.de/viewvc/egroupware/trunk/etemplate/js/et2_extension_nextmatch.js?rev=51649&r1=51648&r2=51649&view=diff
— trunk/etemplate/js/et2_extension_nextmatch.js (original)
+++ trunk/etemplate/js/et2_extension_nextmatch.js Tue Feb 10 00:33:03 2015
@@ -1863,7 +1863,7 @@
beforePrint: function() {
// Add the class, if needed
this.div.addClass(‘print’);
  •   // Trigger resize, so we can fit on a page
      this.dynheight.outerNode.css('max-width',this.div.css('max-width'));
      this.resize();
Modified: trunk/etemplate/templates/default/etemplate2.css
URL: http://svn.stylite.de/viewvc/egroupware/trunk/etemplate/templates/default/etemplate2.css?rev=51649&r1=51648&r2=51649&view=diff
— trunk/etemplate/templates/default/etemplate2.css (original)
+++ trunk/etemplate/templates/default/etemplate2.css Tue Feb 10 00:33:03 2015
@@ -1132,6 +1132,17 @@
.et2_nextmatch .egwGridView_spacer {
display:none;
  • .et2_nextmatch .nextmatch_header {
  •   display: none !important;
  • .egwGridView_outer > thead {
  •   border-bottom: 1px solid;
  • .egwGridView_outer > thead select {
  •   appearance: none;
  •   -webkit-appearance: none;
  •   -moz-appearance: none;
    .egwGridView_grid > tbody > tr {
    page-break-inside: avoid;
Dive into the World of Parallel Programming. The Go Parallel Website,
sponsored by Intel and developed in partnership with Slashdot Media, is your
hub for all things parallel software development, from weekly thought
leadership blogs to news, videos, case studies, tutorials and more. Take a
look and join the conversation now. http://goparallel.sourceforge.net/
eGroupWare-cvs mailing list
