R49628 - /branches/14.1/phpgwapi/js/jsapi/egw.js
Author: ralfbecker
New Revision: 49628
URL: http://svn.stylite.de/viewvc/egroupware?rev=49628&view=rev
fix resize to work with zoom at least up to 125%, by calling resize a 2. time
Modified: branches/14.1/phpgwapi/js/jsapi/egw.js
URL: http://svn.stylite.de/viewvc/egroupware/branches/14.1/phpgwapi/js/jsapi/egw.js?rev=49628&r1=49627&r2=49628&view=diff
— branches/14.1/phpgwapi/js/jsapi/egw.js (original)
+++ branches/14.1/phpgwapi/js/jsapi/egw.js Fri Nov 28 15:01:13 2014
@@ -214,6 +214,38 @@
window.framework.setSidebox.apply(window.framework, JSON.parse(sidebox));
  •   var resize_attempt = 0;
  •   var resize_popup = function()
  •   	var $main_div = $j('#popupMainDiv');
  •   	var $et2 = $j('.et2_container');
  •   	var w = {
  •   		width: egw_getWindowInnerWidth(),
  •   		height: egw_getWindowInnerHeight()
  •   	// Use et2_container for width since #popupMainDiv is full width, but we still need
  •   	// to take padding/margin into account
  •   	var delta_width = w.width - ($et2.outerWidth(true) + ($main_div.outerWidth(true) - $main_div.width()));
  •   	var delta_height = w.height - ($et2.outerHeight(true) + ($main_div.outerHeight(true) - $main_div.height()));
  •   	if (delta_height && egw_getWindowOuterHeight() >= egw.availHeight())
  •   		delta_height = 0;
  •   	if(delta_width != 0 || delta_height != 0)
  •   		window.resizeTo(egw_getWindowOuterWidth() - delta_width+8, egw_getWindowOuterHeight() - delta_height+10);
  •   	// trigger a 2. resize, as one is not enough, if window is zoomed
  •   	if (delta_width && ++resize_attempt < 2)
  •   		window.setTimeout(resize_popup, 50);
  •   	else
  •   		resize_attempt = 0;
  •   // rest needs DOM to be ready
      $j(function() {
      	// load etemplate2 template(s)
@@ -223,27 +255,8 @@
if(popup || window.opener)
// Resize popup when et2 load is done
  •   			jQuery(node).on("load",function() {
  •   				window.setTimeout(function() {
  •   					var w = {
  •   						delta_height = 0;
  •   						window.resizeTo(egw_getWindowOuterWidth() - delta_width,egw_getWindowOuterHeight() - delta_height);
  •   				}, 200);
  •   			jQuery(node).on('load', function() {
      		var et2 = new etemplate2(node, currentapp+".etemplate_new.ajax_process_content.etemplate");
Download BIRT iHub F-Type - The Free Enterprise-Grade BIRT Server
from Actuate! Instantly Supercharge Your Business Reports and Dashboards
with Interactivity, Sharing, Native Excel Exports, App Integration & more
Get technology previously reserved for billion-dollar corporations, FREE
http://pubads.g.doubleclick.net/gampad/clk?id=157005751&iu=/4140/ostg.clktrk
eGroupWare-cvs mailing list
