R48591 - in /branches/14.1/etemplate: js/et2_dataview.js js/et2_dataview_view_resizeable.js templates/default/etemplate2.css
Author: ralfbecker
New Revision: 48591
URL: http://svn.stylite.de/viewvc/egroupware?rev=48591&view=rev
Add some CSS during column resize to indicate which columns are fixed and which columns will change when you resize.
branches/14.1/etemplate/js/et2_dataview.js
branches/14.1/etemplate/js/et2_dataview_view_resizeable.js
branches/14.1/etemplate/templates/default/etemplate2.css
Modified: branches/14.1/etemplate/js/et2_dataview.js
URL: http://svn.stylite.de/viewvc/egroupware/branches/14.1/etemplate/js/et2_dataview.js?rev=48591&r1=48590&r2=48591&view=diff
— branches/14.1/etemplate/js/et2_dataview.js (original)
+++ branches/14.1/etemplate/js/et2_dataview.js Wed Sep 10 13:22:04 2014
@@ -386,6 +386,11 @@
.attr(“align”, “left”)
.append(cont)
.appendTo(this.headTr);
  •   	if(this.columnMgr && this.columnMgr.columns[i])
  •   		column.addClass(this.columnMgr.columns[i].fixedWidth ? 'fixedWidth' : 'relativeWidth');
      	// make column resizable
      	var enc_column = self.columnMgr.getColumnById(col.id);
Modified: branches/14.1/etemplate/js/et2_dataview_view_resizeable.js
URL: http://svn.stylite.de/viewvc/egroupware/branches/14.1/etemplate/js/et2_dataview_view_resizeable.js?rev=48591&r1=48590&r2=48591&view=diff
— branches/14.1/etemplate/js/et2_dataview_view_resizeable.js (original)
+++ branches/14.1/etemplate/js/et2_dataview_view_resizeable.js Wed Sep 10 13:22:04 2014
@@ -53,6 +53,9 @@
  •   	// Indicate resizing is in progress
  •   	$j(_outerElem).addClass('egwResizing');
  •   	// Reset the "didResize" flag
      	didResize = false;
@@ -78,7 +81,7 @@
			.bind("mouseup", function() {
  •   			stopResize();
  •   			stopResize(_outerElem);
      			// Reset text selection
      			_elem[0].onselectstart = null;
@@ -93,8 +96,10 @@
  • function stopResize()
  • function stopResize(_outerElem)
  •   $j(_outerElem).removeClass('egwResizing');
      if (helper != null)
      	helper.remove();
Modified: branches/14.1/etemplate/templates/default/etemplate2.css
URL: http://svn.stylite.de/viewvc/egroupware/branches/14.1/etemplate/templates/default/etemplate2.css?rev=48591&r1=48590&r2=48591&view=diff
— branches/14.1/etemplate/templates/default/etemplate2.css (original)
+++ branches/14.1/etemplate/templates/default/etemplate2.css Wed Sep 10 13:22:04 2014
@@ -1149,6 +1149,13 @@
height: 100%;
min-height: 5px;
    • For resizing (nextmatch columns)
    +table.egwGridView_outer.egwResizing .fixedWidth {
  • opacity: 0.5;
    .egwResizeOverlay {
    position: fixed;
    width: 100%;
Want excitement?
Manually upgrade your production database.
When you want reliability, choose Perforce
Perforce version control. Predictably reliable.
http://pubads.g.doubleclick.net/gampad/clk?id=157508191&iu=/4140/ostg.clktrk
eGroupWare-cvs mailing list
