R48026 - /branches/14.1/phpgwapi/js/jsapi/egw_data.js
Author: hnategh
New Revision: 48026
URL: http://svn.stylite.de/viewvc/egroupware?rev=48026&view=rev
Backport commit r48009, committed by Nathan Gray.
Data improvements:
  • pass UID as additional parameter to data callbacks
  • cache actual data separately from cached fetch response to avoid duplication
  • use callbacks to keep localStorage data consistent with data in memory
  • use callback to update cached fetch response if a record is removed (set to null)
Modified: branches/14.1/phpgwapi/js/jsapi/egw_data.js
URL: http://svn.stylite.de/viewvc/egroupware/branches/14.1/phpgwapi/js/jsapi/egw_data.js?rev=48026&r1=48025&r2=48026&view=diff
— branches/14.1/phpgwapi/js/jsapi/egw_data.js (original)
+++ branches/14.1/phpgwapi/js/jsapi/egw_data.js Mon Aug 11 15:56:29 2014
@@ -35,6 +35,12 @@
var CACHE_LIFETIME = 29; // seconds
    • Cached fetches are differentiated from actual results by using this prefix
    • @type String
  • var CACHE_KEY_PREFIX = ‘cached_fetch_’;
  • var lastModification = null;
    @@ -75,9 +81,11 @@
    var indexes = [];
    for(var i = 0; i < window.localStorage.length; i++)
  •   	if(window.localStorage.key(i).indexOf('cache_'+_prefix) == 0)
  •   		var key = window.localStorage.key(i);
  •   	// This is a cached fetch for many rows
  •   	if(key.indexOf(CACHE_KEY_PREFIX+_prefix) == 0)
      		var cached = JSON.parse(window.localStorage.getItem(key));
      		if(cached.lastModification)
@@ -85,6 +93,23 @@
indexes.push({
key: key,
lastModification: cached.lastModification
  •   		else
  •   			// No way to know how old it is, just remove it
  •   			window.localStorage.removeItem(key);
  •   	// Actual cached data
  •   	else if (key.indexOf(_prefix) == 0)
  •   		var cached = JSON.parse(window.localStorage.getItem(key));
  •   		if(cached.timestamp)
  •   			indexes.push({
  •   				key: key,
  •   				lastModification: cached.timestamp
      		else
@@ -181,9 +206,37 @@
var cache_key = false
if(cache_key = cc.callback.call(cc.context, _context))
  •   				cache_key = 'cache_' + _context.prefix + '::' + cache_key;
  •   				cache_key = CACHE_KEY_PREFIX + _context.prefix + '::' + cache_key;
      				try
  •   					for (var key in _result.data)
  •   						var uid = UID(key, (typeof _context == "object" && _context != null) ? _context.prefix : "");
  •   						// Register a handler on each data so we can know if it is updated or removed
  •   						egw.dataUnregisterUID(uid, null, cache_key);
  •   						egw.dataRegisterUID(uid, function(data, _uid) {
  •   							// If data item is removed, remove it from cached fetch too
  •   							if(data == null)
  •   								var cached = JSON.parse(window.localStorage[this]) || false;
  •   								if(cached && cached.order && cached.order.indexOf(_uid) >= 0)
  •   									cached.order.splice(cached.order.indexOf(_uid),1);
  •   									if(cached.total) cached.total--;
  •   									window.localStorage[this] = JSON.stringify(cached);
  •   								window.localStorage.removeItem(_uid);
  •   							else
  •   								// Update or store data in long-term storage
  •   								window.localStorage[_uid] = JSON.stringify({timestamp: (new Date).getTime(), data: data});
  •   						},cache_key);
  •   					// Don't keep data in long-term cache with request also
  •   					_result.data = {};
      					window.localStorage.setItem(cache_key,JSON.stringify(_result));
      				catch (e)
@@ -324,7 +377,7 @@
      				var cached = window.localStorage.getItem(cache_key);
      				if(cached)
@@ -388,7 +441,7 @@
* Turn on long-term client side cache of a particular request
* (cache the nextmatch query results) for fast, immediate response
  •    * with old data.
  •    * with old data.
       * The request is still sent to the server, and the cache is updated
       * with fresh data, and any needed callbacks are called again with
@@ -509,6 +562,9 @@
			// Delete the data from the localStorage
			delete localStorage[uid];
  •   		// We don't clean long-term storage because of age until it runs
  •   		// out of space
    }, CLEANUP_INTERVAL);
    @@ -551,7 +607,13 @@
    // Update the timestamp and call the given callback function
    localStorage[_uid].timestamp = (new Date).getTime();
  •   		_callback.call(_context, localStorage[_uid].data);
  •   		_callback.call(_context, localStorage[_uid].data, _uid);
  •   	// Check long-term storage
  •   	else if(window.localStorage && window.localStorage[_uid])
  •   		localStorage[_uid] = JSON.parse(window.localStorage[_uid]);
      	else if (_execId && _widgetId)
@@ -694,7 +756,8 @@
try {
registeredCallbacks[_uid][i].callback.call(
registeredCallbacks[_uid][i].context,
  •   					_data
  •   					_data,
  •   					_uid
      			} catch (e) {
      				// Remove this callback from the list
eGroupWare-cvs mailing list
