R47404 - /trunk/egroupware/doc/rpm-build/debian.changes
Author: ralfbecker
New Revision: 47404
URL: http://svn.stylite.de/viewvc/egroupware?rev=47404&view=rev
Changelog for 14.1.20140627
Modified: trunk/egroupware/doc/rpm-build/debian.changes
URL: http://svn.stylite.de/viewvc/egroupware/trunk/egroupware/doc/rpm-build/debian.changes?rev=47404&r1=47403&r2=47404&view=diff
— trunk/egroupware/doc/rpm-build/debian.changes (original)
+++ trunk/egroupware/doc/rpm-build/debian.changes Fri Jun 27 09:03:51 2014
@@ -1,3 +1,15 @@
+egroupware-epl (14.1.20140627-1) hardy; urgency=low
    • 14.1 release candidate: you need to visit setup for manual (non-package) installations!
    • many bugfixes in all applications
    • all apps: custom-fields are now stored in own egw_customfields table (no more limit on number), site configurations get now JSON serialized
    • PostgreSQL: fixed not working installation (access to not yet existing table stalls transaction)
    • PostgreSQL: fixed not working update from 1.8, as not existing FMail tables stalled update
    • PostgreSQL/Addressbook: fixed not displayed pictures
    • Notification/Mail: make sure acc_smtp_username is used (if available), to cope with strict mailserver settings to prevent faking sender information
  • – Ralf Becker rb@stylite.de Fri, 27 Jun 2014 09:05:09 +0200
egroupware-epl (14.1.20140617-1) hardy; urgency=low
  • ProjectManager: fixed parent projects were not updated with changes (you had to run sync-all manually
Open source business process management suite built on Java and Eclipse
Turn processes into business applications with Bonita BPM Community Edition
Quickly connect people, data, and systems into organized workflows
Winner of BOSSIE, CODIE, OW2 and Gartner awards
http://p.sf.net/sfu/Bonitasoft
eGroupWare-cvs mailing list
