R34525 - in /trunk/felamimail: inc/ js/jscode/ templates/default/ templates/jerryr/
Author: leithoff
New Revision: 34525
URL: http://www.egroupware.org/viewvc/egroupware?rev=34525&view=rev
fix for egroupware.org tracker bug #2925; wrong from/to assignment to cols; make attachment icon clickable in MessageList
trunk/felamimail/inc/class.uifelamimail.inc.php
trunk/felamimail/inc/class.uiwidgets.inc.php
trunk/felamimail/js/jscode/viewMainScreen.js
trunk/felamimail/templates/default/mainscreen.tpl
trunk/felamimail/templates/jerryr/app.css
trunk/felamimail/templates/jerryr/mainscreen.tpl
Modified: trunk/felamimail/inc/class.uifelamimail.inc.php
URL: http://www.egroupware.org/viewvc/egroupware/trunk/felamimail/inc/class.uifelamimail.inc.php?rev=34525&r1=34524&r2=34525&view=diff
— trunk/felamimail/inc/class.uifelamimail.inc.php (original)
+++ trunk/felamimail/inc/class.uifelamimail.inc.php Tue Apr 5 15:19:35 2011
@@ -985,7 +985,7 @@
#$headers = $this->bofelamimail->getHeaders($this->startMessage, $maxMessages, $this->sort);
$headerCount = count($headers[‘header’]);
if ($this->bofelamimail->isSentFolder($this->mailbox)
>> $this->bofelamimail->isDraftFolder($this->mailbox)
>> $this->bofelamimail->isTemplateFolder($this->mailbox)) {
@@ -993,19 +993,22 @@
} else {
$this->t->set_var(‘lang_from’,lang(“from”));
$msg_icon_sm = $GLOBALS[‘egw’]->common->image(‘felamimail’,‘msg_icon_sm’);
// determine how to display the current folder: as sent folder (to address visible) or normal (from address visible)
$folderType = $this->bofelamimail->getFolderType($this->mailbox);
  •   		$this->t->set_var('header_rows',
  •   			$uiwidgets->messageTable(
  •   		$messageTable =	$uiwidgets->messageTable(
      				$headers,
      				$folderType,
      				$this->mailbox,
      				$userPreferences['message_newwindow'],
      				$userPreferences['rowOrderStyle'],
  •   				($this->bofelamimail->sessionData['previewMessage']?$this->bofelamimail->sessionData['previewMessage']:0)
  •   				($this->bofelamimail->sessionData['previewMessage']?$this->bofelamimail->sessionData['previewMessage']:0));
+//error_log($messageTable);
  •   		$this->t->set_var('header_rows', $messageTable	);
			$firstMessage = $headers['info']['first'];
			$lastMessage = $headers['info']['last'];
Modified: trunk/felamimail/inc/class.uiwidgets.inc.php
URL: http://www.egroupware.org/viewvc/egroupware/trunk/felamimail/inc/class.uiwidgets.inc.php?rev=34525&r1=34524&r2=34525&view=diff
— trunk/felamimail/inc/class.uiwidgets.inc.php (original)
+++ trunk/felamimail/inc/class.uiwidgets.inc.php Tue Apr 5 15:19:35 2011
@@ -339,6 +339,7 @@
	function get_grid_js($foldertype,$_folderName,$offset=0,$headers=false,$getAllIds=false)
  •   	//error_log(__METHOD__.__LINE__.array2string(array('Foldertype'=>$foldertype,'Foldername'=>$_folderName,'Offset'=>$offset,'getAllIds'=>$getAllIds)));
      	$js = '<script type="text/javascript">
$(document).ready(function() {
// Create the base objects and feed them with data
@@ -381,6 +382,7 @@
  •   	//error_log(__METHOD__.__LINE__.$js);
      	return $js;
@@ -437,7 +439,7 @@
(array)$this->sessionData[‘messageFilter’]
  •   	//error_log(__METHOD__.__LINE__.' Data:'.array2string($rvs));
  •   	//error_log(__METHOD__.__LINE__.' Data:'.array2string($sortResult));
      	$cols = array('check','status','attachments','subject','toaddress','fromaddress','date','size');
      	return $this->header2gridelements($sortResult['header'],$cols, $_folderName, $uidOnly,$folderType,$dataForXMails=50,$previewMessage);
@@ -473,13 +475,13 @@
“id” => “toaddress”, // sent or drafts or template folder means foldertype > 0, use to address instead of from
"caption" => ‘’.lang(“to”).’’,
“width” => “120px”,
  •   					"visibility" =>  ($foldertype>0?EGW_COL_VISIBILITY_INVISIBLE:EGW_COL_VISIBILITY_VISIBLE)
  •   					"visibility" =>  ($foldertype>0?EGW_COL_VISIBILITY_VISIBLE:EGW_COL_VISIBILITY_INVISIBLE)
      				array(
      					"id" => "fromaddress",// sent or drafts or template folder means foldertype > 0, use to address instead of from
      					"caption" => '<a id="gridHeaderFrom" href="#" onclick="changeSorting(\'from\', this); return false;">'.lang("from").'</a>',
      					"width" => "120px",
      				array(
      					"id" => "subject",
@@ -749,6 +751,15 @@
substr($header[‘mimetype’],0,5) == ‘audio’ ||
substr($header[‘mimetype’],0,5) == ‘video’)
  •   			$linkDataAttachments = array (
  •   				'menuaction'    => 'felamimail.uidisplay.displayAttachments',
  •   				'showHeader'	=> 'false',
  •   				'mailbox'    => base64_encode($_folderName),
  •   				'uid'		=> $header['uid'],
  •   				'id'		=> $header['id'],
  •   			$windowName =  'displayMessage_'.$header['uid'];
  •   			$image = html::image('felamimail','attach');
      			if (//$header['mimetype'] != 'multipart/mixed' &&
      				$header['mimetype'] != 'multipart/signed'
@@ -762,6 +773,10 @@
$attachments = $this->bofelamimail->getMessageAttachments($header[‘uid’]);
if (count($attachments)<1) $image = ’ ';
  •   			if (count($attachments)>0) $image = "<a name=\"subject_url\" href=\"#\"
  •   				onclick=\"fm_handleAttachmentClick(false,'".$GLOBALS['egw']->link('/index.php',$linkDataAttachments)."', '".$windowName."', this); return false;\"
  •   				title=\"".$header['subject']."\">".$image."</a>";
  •   			$attachmentFlag = $image;
      		} else {
      			$attachmentFlag ='&nbsp;';
@@ -991,6 +1006,7 @@
$jscall= “sendNotifyMS(”.$headerData[‘uid’]."); ";
//if (strpos( array2string($flags),‘Seen’)===false) $this->bofelamimail->flagMessages(‘read’, $headerData[‘uid’]);
if ($_folderType > 0) {
@@ -1109,12 +1125,11 @@
$uidisplay->uid = $headerData[‘uid’];
$uidisplay->mailbox = $_folderName;
$mailData = $uidisplay->get_load_email_data($headerData[‘uid’], $partID);
				$iframe_url = $mailData['src'];
				$jscall .= $mailData['onload'];
				$script = $mailData['script'];
  •   			unset($uidisplay);
      		//_debug_array($GLOBALS['egw']->link('/index.php',$linkData));
      		$IFRAMEBody = "<TABLE BORDER=\"1\" rules=\"rows\" style=\"table-layout:fixed;width:100%;\">
      						<TR class=\"th\" style=\"width:100%;\">
Modified: trunk/felamimail/js/jscode/viewMainScreen.js
URL: http://www.egroupware.org/viewvc/egroupware/trunk/felamimail/js/jscode/viewMainScreen.js?rev=34525&r1=34524&r2=34525&view=diff
— trunk/felamimail/js/jscode/viewMainScreen.js (original)
+++ trunk/felamimail/js/jscode/viewMainScreen.js Tue Apr 5 15:19:35 2011
@@ -9,6 +9,10 @@
if (typeof activeFolder == ‘undefined’) var activeFolder = egw_appWindow(‘felamimail’).activeFolder;
if (typeof activeFolderB64 == ‘undefined’) var activeFolderB64 = egw_appWindow(‘felamimail’).activeFolderB64;
if (typeof activityImagePath == ‘undefined’) var activityImagePath = egw_appWindow(‘felamimail’).activityImagePath;
+if (typeof actionManager == ‘undefined’) var actionManager = egw_appWindow(‘felamimail’).actionManager;
+if (typeof objectManager == ‘undefined’) var objectManager = egw_appWindow(‘felamimail’).objectManager;
+if (typeof mailGrid == ‘undefined’) var mailGrid = egw_appWindow(‘felamimail’).mailGrid;
// how many row are selected currently
if (typeof checkedCounter == ‘undefined’) var checkedCounter=egw_appWindow(‘felamimail’).checkedCounter;
@@ -725,8 +729,64 @@
aElements[1].style.fontWeight=‘normal’;
    • Handles message clicks and distinguishes between double clicks and single clicks
    +function fm_handleAttachmentClick(_double, _url, _windowName, _node)
  • if (_double)
  •   // Unset the given message url - the timeout which was triggered in the
  •   // click handler will now no longer call the fm_readMessage function
  •   delete (felamimail_messageUrls[_url]);
  •   window.setTimeout(function () {
  •   if (typeof felamimail_messageUrls[_url] == "undefined")
  •   	fm_readAttachments(_url, _windowName, _node);
  •   	//alert('fm_handleAttachmentClick:'+' is double');
  •   }, felamimail_dblclick_speed);
  •   //mailGrid.dataRoot.actionObject.setAllSelected(false);
  • else
  •   // Check whether the given url is already queued. Only continue if this
  •   // is not the case
  •   	// Queue the url
  •   	felamimail_messageUrls[_url] = true;
  •   	// Wait "felamimail_dblclick_speed" milliseconds. Only if the doubleclick
  •   	// event doesn't occur in this time, trigger the single click function
  •   		if (typeof felamimail_messageUrls[_url] == "boolean")
  •   			//alert('fm_handleAttachmentClick:'+' is single');
  • var allSelected = mailGrid.dataRoot.actionObject.getSelectedObjects();
  • // allSelected[i].id hält die id
  • // zurückseten iteration über allSelected (getSelectedObjects) und dann allSelected[i].setSelected(false);
  • for (var i=0; i<allSelected.length; i++)
  •   if (allSelected[i].id.length>0)
  •   	allSelected[i].setSelected(false);
  •   	allSelected[i].setFocused(true);
  •   	//alert('fm_handleMessageClick:'+allSelected[i].id);
function fm_readAttachments(_url, _windowName, _node) {
egw_openWindowCentered(_url, _windowName, 750, 220);
  • egw_appWindow(‘felamimail’).xajax_doXMLHTTP(“felamimail.ajaxfelamimail.refreshFolder”);
  • mailGrid.dataRoot.actionObject.setAllSelected(false);
function fm_clearSearch() {
Modified: trunk/felamimail/templates/default/mainscreen.tpl
URL: http://www.egroupware.org/viewvc/egroupware/trunk/felamimail/templates/default/mainscreen.tpl?rev=34525&r1=34524&r2=34525&view=diff
— trunk/felamimail/templates/default/mainscreen.tpl (original)
+++ trunk/felamimail/templates/default/mainscreen.tpl Tue Apr 5 15:19:35 2011
@@ -122,7 +122,7 @@
		<form name="formMessageList" id="formMessageList">
  •   	<div id="divMessageList" style="overflow:auto; height:auto; margin-left:0px; margin-right:0px; margin-top:0px; margin-bottom: 0px; z-index:90; border : 1px solid Silver;">
  •   	<div id="divMessageList" style="margin-left:0px; margin-right:0px; margin-top:0px; margin-bottom: 0px; z-index:90; border : 1px solid Silver;">
      		<!-- <table BORDER="0" style="width:98%; ppadding-left:2; table-layout: fixed;" cellspacing="100" cellpadding="100"> -->
      			{header_rows}
      		<!-- </table> -->
Modified: trunk/felamimail/templates/jerryr/app.css
URL: http://www.egroupware.org/viewvc/egroupware/trunk/felamimail/templates/jerryr/app.css?rev=34525&r1=34524&r2=34525&view=diff
— trunk/felamimail/templates/jerryr/app.css (original)
+++ trunk/felamimail/templates/jerryr/app.css Tue Apr 5 15:19:35 2011
@@ -171,20 +171,6 @@
height : 14px;
padding: 0;
TR.header_row_DS, TR.header_row_ADS
Modified: trunk/felamimail/templates/jerryr/mainscreen.tpl
URL: http://www.egroupware.org/viewvc/egroupware/trunk/felamimail/templates/jerryr/mainscreen.tpl?rev=34525&r1=34524&r2=34525&view=diff
— trunk/felamimail/templates/jerryr/mainscreen.tpl (original)
+++ trunk/felamimail/templates/jerryr/mainscreen.tpl Tue Apr 5 15:19:35 2011
@@ -123,7 +123,7 @@
  •   	<div id="divMessageList" style="overflow:auto; height:auto; margin-left:0px; margin-right:0px; margin-top:0px; margin-bottom: 0px; z-index:90; border : 1px solid #9f9f9f; border-top: 0px; background-color: white;">
  •   	<div id="divMessageList" style="margin-left:0px; margin-right:0px; margin-top:0px; margin-bottom: 0px; z-index:90; border : 1px solid #9f9f9f; border-top: 0px; background-color: white;">
      			{header_rows}
      		<!-- </table> -->
@@ -180,7 +180,7 @@
divheight the end size height of the table outer div */
var tabnotavail = false;
var tableheight = 300; //$(tableMessageTableList).height();
  •   	if (mailGrid != null) tableheight = mailGrid.getDataHeight()+5;
  •   	if (mailGrid != null) tableheight = mailGrid.getDataHeight();
      	if (tableheight == 0 || isNaN(tableheight)) // set defaults to compute with, if the property is not set
      		tabnotavail = true;
@@ -220,7 +220,7 @@
//alert(‘divMessageList Height:’+divheight);
//alert(‘iframe height:’+iframeheight);
divMessageTableList.style.height = divheight + ‘px’;
  •   	if (mailGrid != null) mailGrid.resize($(divMessageTableList).outerWidth(), divheight-10);
  •   	if (mailGrid != null) mailGrid.resize($(divMessageTableList).outerWidth(), divheight-90);
      	if (typeof iframe != 'undefined' && typeof tdiframe != 'undefined' && iframe != null && tdiframe != null)
Xperia™ PLAY
It’s a major breakthrough. An authentic gaming
smartphone on the nation’s most reliable network.
And it wants your games.
http://p.sf.net/sfu/verizon-sfdev
eGroupWare-cvs mailing list
