R32141 - /trunk/phpgwapi/templates/idots/js/slidereffects.js
Author: nathangray
New Revision: 32141
URL: http://www.egroupware.org/viewvc/egroupware?rev=32141&view=rev
Attempt at a fix for error that prevented sidebox menu from sliding out in IE8
Modified: trunk/phpgwapi/templates/idots/js/slidereffects.js
URL: http://www.egroupware.org/viewvc/egroupware/trunk/phpgwapi/templates/idots/js/slidereffects.js?rev=32141&r1=32140&r2=32141&view=diff
— trunk/phpgwapi/templates/idots/js/slidereffects.js (original)
+++ trunk/phpgwapi/templates/idots/js/slidereffects.js Thu Sep 16 22:06:48 2010
@@ -104,7 +104,7 @@
		//temporarly hide all selectboxes to fix IE bug with z-index
  •   	if(document.all)
  •   	if(document.all && document.all instanceof Array)
      		for (var i=0; i<document.all.length; i++) {
      			o = document.all(i)
@@ -115,7 +115,6 @@
  •   if (obj.container) {
      	obj.over = true
@@ -155,7 +154,7 @@
if (obj.open && !obj.aniTimer) obj.startSlide(false)
					//show all selectboxes again to fix IE bug with z-index
  •   				if(document.all)
      						o = document.all(i)
Start uncovering the many advantages of virtual appliances
and start using them to simplify application deployment and
accelerate your shift to cloud computing.
http://p.sf.net/sfu/novell-sfdev2dev
eGroupWare-cvs mailing list
