R29437 - /trunk/sitemgr/modules/class.module_navigation.inc.php
Author: ralfbecker
New Revision: 29437
URL: http://www.egroupware.org/viewvc/egroupware?rev=29437&view=rev
“only add content for the active nav_type, as otherwise we can NOT longer uncheck checkboxes,
if the same name is used for multiple nav_type’s”
Modified: trunk/sitemgr/modules/class.module_navigation.inc.php
URL: http://www.egroupware.org/viewvc/egroupware/trunk/sitemgr/modules/class.module_navigation.inc.php?rev=29437&r1=29436&r2=29437&view=diff
— trunk/sitemgr/modules/class.module_navigation.inc.php (original)
+++ trunk/sitemgr/modules/class.module_navigation.inc.php Sun Mar 7 19:02:48 2010
@@ -269,9 +269,22 @@
$tabs .= ‘
’. $description. ‘’;
if(count($this->nav_args[$id]) >= 1)
  •   			// only add content for the active nav_type, as otherwise we can NOT longer uncheck checkboxes,
  •   			// if the same name is used for multiple nav_type's
  •   			if ($id != $this->block->arguments['nav_type'])
  •   				$save_args =& $this->block->arguments;
  •   				unset($this->block->arguments);
      			foreach (parent::get_user_interface() as $param)
      				$tabs .= '<tr><td>'.$param['label'].'</td><td>'.$param['form'].'</td></tr>';
  •   			// restore arguments
  •   			if ($save_args)
  •   				$this->block->arguments =& $save_args;
  •   				unset($save_args);
      		else
@@ -500,7 +513,7 @@
array_push($cat_tree,$cat_id); array_push($cat_tree_data,$cat);
  •   		if($arguments['expand'] && $cat_id == $this->page->cat_id && $cat['depth'] >= $arguments['max_cat_depth'])
      			$cat_tree2 = $cat_tree;	$cat_tree_data2 = $cat_tree_data;
eGroupWare-cvs mailing list
