R28792 - /trunk/egroupware/doc/rpm-build/post_install.php
Author: ralfbecker
New Revision: 28792
URL: http://www.egroupware.org/viewvc/egroupware?rev=28792&view=rev
“using an enviroment var to preseed post-install”
Modified: trunk/egroupware/doc/rpm-build/post_install.php
URL: http://www.egroupware.org/viewvc/egroupware/trunk/egroupware/doc/rpm-build/post_install.php?rev=28792&r1=28791&r2=28792&view=diff
— trunk/egroupware/doc/rpm-build/post_install.php (original)
+++ trunk/egroupware/doc/rpm-build/post_install.php Mon Dec 7 19:26:28 2009
@@ -9,7 +9,7 @@
  • @version $Id$
-if (isset($_SERVER[‘HTTP_HOST’])) // security precaution: forbit calling setup-cli as web-page
+if (isset($_SERVER[‘HTTP_HOST’])) // security precaution: forbit calling post_install as web-page
die(‘
rpm_post_install.php must NOT be called as web-page --> exiting !!!
@@ -37,12 +37,12 @@
‘admin_passwd’=> randomstring(),
‘lang’ => ‘en’, // languages for admin user and extra lang to install
’charset’ => ‘utf-8’,
  • ‘start_db’ => ‘/etc/init.d/mysqld’,
  • ‘start_db’ => ‘/sbin/service mysqld’,
    ‘autostart_db’ => ‘/sbin/chkconfig --level 345 mysqld on’,
  • ‘start_webserver’ => ‘/etc/init.d/httpd’,
  • ‘start_webserver’ => ‘/sbin/service httpd’,
    ‘autostart_webserver’ => ‘/sbin/chkconfig --level 345 httpd on’,
    ‘distro’ => ‘rh’,
  • ‘account-auth’ => ‘sql,sql’,
  • ‘account-auth’ => ‘sql’,
    ‘account_min_id’ => ‘’,
    ‘ldap_suffix’ => ‘dc=local’,
    ‘ldap_host’ => ‘localhost’,
    @@ -89,9 +89,9 @@
    case ‘suse’:
    $config[‘php’] = ‘/usr/bin/php5’;
  •   	$config['start_db'] = '/etc/init.d/mysql';
  •   	$config['start_db'] = '/sbin/service mysql';
      	$config['autostart_db'] = '/sbin/chkconfig --level 345 mysql on';
  •   	$config['start_webserver'] = '/etc/init.d/apache2';
  •   	$config['start_webserver'] = '/sbin/service apache2';
      	$config['autostart_webserver'] = '/sbin/chkconfig --level 345 apache2 on';
      	$config['ldap_suffix'] = 'dc=site';
      	$config['ldap_admin'] = $config['ldap_root_dn'] = 'cn=Administrator,$suffix';
@@ -101,9 +101,9 @@
$config[‘ldap_group_context’] = ‘ou=group,$base’;
break;
case ‘debian’:
  •   	$config['start_db'] = '/usr/sbin/service mysql';
      	$config['autostart_db'] = '/usr/sbin/update-rc.d mysql defaults';
  •   	$config['start_webserver'] = '/usr/sbin/service apache2';
      	$config['autostart_webserver'] = '/usr/sbin/update-rc.d apache2 defaults';
      	break;
      default:
@@ -118,6 +118,27 @@
// read config from command line
$argv = $_SERVER[‘argv’];
$prog = array_shift($argv);
+// check if we have EGW_POST_INSTALL set and prepend it to the command line (command line has precedence)
+if (($config_set = isset($_ENV[‘EGW_POST_INSTALL’]) ? $_ENV[‘EGW_POST_INSTALL’] : @$_SERVER[‘EGW_POST_INSTALL’]))
  • $conf = array();
  • $config_set = explode(’ ',$config_set);
  • while(($val = array_shift($config_set)))
  •   if (($quote = $val[0]) == "'" || $quote == '"')	// arguments might be quoted with ' or "
  •   	while (substr($val,-1) != $quote)
  •   		if (!$config_set) throw new Exception('Invalid EGW_POST_INSTALL enviroment variable!');
  •   		$val .= ' '.array_shift($config_set);
  •   	$val = substr($val,1,-1);
  •   $conf[] = $val;
  • $argv = array_merge($conf,$argv);
$auth_type_given = false;
while(($arg = array_shift($argv)))
@@ -437,7 +458,10 @@
echo “options and their defaults:\n”;
foreach($config as $name => $default)
  •   if (in_array($name,array('config_passwd','db_pass','admin_passwd'))) $default = '<16 char random string>';
  •   if (in_array($name,array('config_passwd','db_pass','admin_passwd','ldap_root_pw')))
  •   	$default = '<16 char random string>';
      echo '--'.str_pad($name,20).$default."\n";
    if ($error)
Join us December 9, 2009 for the Red Hat Virtual Experience,
a free event focused on virtualization and cloud computing.
Attend in-depth sessions from your desk. Your couch. Anywhere.
http://p.sf.net/sfu/redhat-sfdev2dev
eGroupWare-cvs mailing list
