R28623 - in /branches/1.6: calendar/inc/ phpgwapi/inc/horde/Horde/SyncML/Sync/ syncml/calendar/lib/ syncml/contacts/lib/ syn
Author: jlehrke
New Revision: 28623
URL: http://www.egroupware.org/viewvc/egroupware?rev=28623&view=rev
Optimized SyncML memory footprint; fixes various filter issues
branches/1.6/calendar/inc/class.calendar_ical.inc.php
branches/1.6/calendar/inc/class.calendar_so.inc.php
branches/1.6/phpgwapi/inc/horde/Horde/SyncML/Sync/TwoWaySync.php
branches/1.6/syncml/calendar/lib/api.php
branches/1.6/syncml/contacts/lib/api.php
branches/1.6/syncml/inc/class.syncml_hooks.inc.php
branches/1.6/syncml/notes/lib/api.php
branches/1.6/syncml/tasks/lib/api.php
Modified: branches/1.6/calendar/inc/class.calendar_ical.inc.php
URL: http://www.egroupware.org/viewvc/egroupware/branches/1.6/calendar/inc/class.calendar_ical.inc.php?rev=28623&r1=28622&r2=28623&view=diff
— branches/1.6/calendar/inc/class.calendar_ical.inc.php (original)
+++ branches/1.6/calendar/inc/class.calendar_ical.inc.php Sun Nov 29 21:59:52 2009
@@ -121,6 +121,13 @@
var $uidExtension = false;
    • user preference: calendar to synchronize with
    • @var int
  • var $calendarOwner = 0;
    • user preference: use server timezone for exports to device
    • @var boolean
      @@ -147,7 +154,7 @@
    • @var boolean
  • var $log = false;
  • var $log = true;
    var $logfile="/tmp/log-vcal";
@@ -307,7 +314,7 @@
foreach ((array)$event[‘participants’] as $uid => $status)
if (!($info = $this->resource_info($uid))) continue;
  •   					if ($uid == $event['owner']) continue; // Organizer
  •   					if ($uid == $event['owner'] && $status == 'A') continue; // Organizer
      					// RB: MAILTO href contains only the email-address, NO cn!
      					$attributes['ATTENDEE'][]	= $info['email'] ? 'MAILTO:'.$info['email'] : '';
      					// ROLE={CHAIR|REQ-PARTICIPANT|OPT-PARTICIPANT|NON-PARTICIPANT|X-*}
@@ -1010,6 +1017,7 @@
unset($event_to_store);
$event[‘reference’] = $event_info[‘master_event’][‘id’];
$event[‘category’] = $event_info[‘master_event’][‘category’];
  •   					$event['owner'] = $event_info['master_event']['owner'];
      				$event_to_store = $event; // prevent $event from being changed by update method
@@ -1228,6 +1236,14 @@
$deviceInfo[‘tzid’])
$this->useServerTZ = ($deviceInfo[‘tzid’] == 1);
  •   	if (isset($GLOBALS['egw_info']['user']['preferences']['syncml']['calendar_owner']))
  •   		$owner = $GLOBALS['egw_info']['user']['preferences']['syncml']['calendar_owner'];
  •   		if (0 < (int)$owner && $this->check_perms(EGW_ACL_EDIT,0,$owner))
  •   			$this->calendarOwner = $owner;
      	if (!isset($this->productManufacturer) ||
      		 $this->productManufacturer == '' ||
@@ -1571,7 +1587,7 @@
$recurence = $attributes[‘value’];
$type = preg_match(’/FREQ=([^;: ]+)/i’,$recurence,$matches) ? $matches[1] : $recurence[0];
// vCard 2.0 values for all types
  •   			if (preg_match('/UNTIL=([0-9T]+)/',$recurence,$matches))
  •   			if (preg_match('/UNTIL=([0-9TZ]+)/',$recurence,$matches))
      				$vcardData['recur_enddate'] = $this->vCalendar->_parseDateTime($matches[1]);
@@ -1841,8 +1857,8 @@
$vcardData[‘category’] = array();
break;
  •   		case 'ORGANIZER':	// will be written direct to the event
      		case 'ATTENDEE':
      			if (isset($attributes['params']['PARTSTAT']))
      		    	$attributes['params']['STATUS'] = $attributes['params']['PARTSTAT'];
@@ -1902,21 +1918,26 @@
				//elseif (//$attributes['params']['CUTYPE'] == 'GROUP'
  •   			elseif (preg_match('/(.*) Group/', $searcharray['n_fn'], $matches)
  •   					&& $status && $status != 'U')
  •   			elseif (preg_match('/(.*) Group/', $searcharray['n_fn'], $matches))
      				if (($uid =  $GLOBALS['egw']->accounts->name2id($matches[1], 'account_lid', 'g')))
      					//Horde::logMessage("vevent2egw: group participant $uid",
  •   	    				//			__FILE__, __LINE__, PEAR_LOG_DEBUG);
  •   					$members = $GLOBALS['egw']->accounts->members($uid, true);
  •   					if (in_array($this->user, $members))
  •   						//Horde::logMessage("vevent2egw: set status to " . $status,
  •   						$event['participants'][$this->user] = $status;
  •   					if ($status != 'U')
  •   						// User tries to reply to the group invitiation
  •   						$status = 'U'; // keep the group
  •   				else continue; // can't find this group
      			elseif ($attributes['value'] == 'Unknown')
@@ -1946,13 +1967,9 @@
switch($attributes[‘name’])
case ‘ATTENDEE’:
  •   					if ($status)
  •   						$event['participants'][$uid] = $status;
  •   					else
  •   						$event['participants'][$uid] = ($uid == $event['owner'] ? 'A' : 'U');
  •   					if (!$status)
  •   						$status = ($uid == $event['owner'] ? 'A' : 'U');
      					if (!isset($attributes['params']['ROLE']) || $attributes['params']['ROLE'] != 'ORGANIZER')
@@ -1962,17 +1979,19 @@
case ‘ORGANIZER’:
$hasOrganizer = true;
  •   					if (is_numeric($uid))
  •   					if (is_numeric($uid) && ($uid == $this->calendarOwner || !$this->calendarOwner))
  •   						// we can store the ORGANIZER as event owner
      						$event['owner'] = $uid;
      					else
      						$event['owner'] = $this->user;
  •   					// RalfBecker: this is not allways true, owner can choose to NOT participate in EGroupware
  •   					$event['participants'][$uid] = 'A';
  •   					break;
  •   					if (!isset($event['participants'][$uid]))
      			break;
      		case 'CREATED':		// will be written direct to the event
@@ -1984,8 +2003,7 @@
  •   if (!$hasOrganizer && $this->productManufacturer == 'groupdav'
  •   	&& !isset($event['participants'][$this->user]))
  •   if (!$hasOrganizer && !isset($event['participants'][$this->user]))
      	// according to iCalendar standard, ORGANIZER not used for events in the own calendar
      	$event['participants'][$this->user] = 'A';
@@ -2059,8 +2077,13 @@
break;
  •   if ($this->calendarOwner) $event['owner'] = $this->calendarOwner;
      //Horde::logMessage("vevent2egw:\n" . print_r($event, true),
  •    if ($this->log)
  •   	error_log(__FILE__.'['.__LINE__.'] '.__METHOD__."()\n".array2string($event)."\n",3,$this->logfile);
      return $event;
@@ -2250,8 +2273,8 @@
$recurrence_event[‘start’] = $event[‘reference’];
$recurrence_event[‘end’] = $event[‘reference’] + ($master_event[‘end’] - $master_event[‘start’]);
// check for changed data
  •   				foreach (array('start','end','uid','owner','title','description',
  •   					'location','priority','public','special','non_blocking') as $key)
  •   				foreach (array('start','end','uid','title','location',
  •   							'priority','public','special','non_blocking') as $key)
      					if (!empty($event[$key]) && $recurrence_event[$key] != $event[$key])
Modified: branches/1.6/calendar/inc/class.calendar_so.inc.php
URL: http://www.egroupware.org/viewvc/egroupware/branches/1.6/calendar/inc/class.calendar_so.inc.php?rev=28623&r1=28622&r2=28623&view=diff
— branches/1.6/calendar/inc/class.calendar_so.inc.php (original)
+++ branches/1.6/calendar/inc/class.calendar_so.inc.php Sun Nov 29 21:59:52 2009
@@ -892,6 +892,8 @@
function participants($cal_id,$participants,$change_since=0,$add_only=false)
  •   $recurrences = array();
  •   // remove group-invitations, they are NOT stored in the db
      foreach($participants as $uid => $status)
@@ -907,8 +909,15 @@
$where[0] = ‘(cal_recur_date=0 OR cal_recur_date >= ‘.(int)$change_since.’)’;
  •   if ($change_since !== false)	// update existing entries
  •   	// find all existing recurrences
  •   	foreach($this->db->select($this->user_table,'DISTINCT cal_recur_date',$where,__LINE__,__FILE__,false,'','calendar') as $row)
  •   		$recurrences[] = $row['cal_recur_date'];
  •   	// update existing entries
      	$existing_entries = $this->db->select($this->user_table,'DISTINCT cal_user_type,cal_user_id',$where,__LINE__,__FILE__,false,'','calendar');
      	// create a full list of participants which already exist in the db
@@ -956,16 +965,7 @@
	if (count($participants))	// participants which need to be added
  •   	// find all recurrences, as they all need the new parts to be added
  •   	if ($change_since !== false)	// existing entries
  •   	if (!count($recurrences)) $recurrences[] = 0;	// insert the default one
  •   	if (!count($recurrences)) $recurrences[] = 0;   // insert the default recurrence
      	// update participants
@@ -1075,7 +1075,7 @@
		$type = '';
		$id = null;
  •   	$this->split_user($uid,$type,$id);
  •   	self::split_user($uid,$type,$id);
      	$this->db->insert($this->user_table,array(
      		'cal_status'	 => $status !== true ? $status[0] : 'U',
      		'cal_quantity'	=> substr($status,1) ? substr($status,1) : 1,
@@ -1270,7 +1270,7 @@
$user_type = ‘’;
$user_id = null;
  •   	$this->split_user($old_user,$user_type,$user_id);
  •   	self::split_user($old_user,$user_type,$user_id);
      	if ($user_type == 'u')	// only accounts can be owners of events
@@ -1324,14 +1324,24 @@
* @param int $cal_id
* @param int $uid participant uid
    • @param int $start=0 if != 0: startdate of the search/list (servertime)
    • @param int $end=0 if != 0: enddate of the search/list (servertime)
    • @return array recur_date => status pairs (index 0 => main status)
  • function get_recurrences($cal_id, $uid)
  • function get_recurrences($cal_id, $uid, $start=0, $end=0)
    $user_type = $user_id = null;
  •   $this->split_user($uid, $user_type, $user_id);
  •   self::split_user($uid, $user_type, $user_id);
      $participant_status = array();
      $where = array('cal_id' => $cal_id);
  •   if ($start != 0 && $end == 0) $where[] = '(cal_recur_date = 0 OR cal_recur_date >= ' . (int)$start . ')';
  •   if ($start == 0 && $end != 0) $where[] = '(cal_recur_date = 0 OR cal_recur_date <= ' . (int)$end . ')';
  •   if ($start != 0 && $end != 0)
  •   	$where[] = '(cal_recur_date = 0 OR (cal_recur_date >= ' . (int)$start .
  •   				' AND cal_recur_date <= ' . (int)$end . '))';
      	// inititalize the array
@@ -1342,6 +1352,13 @@
‘cal_user_type’ => $user_type ? $user_type : ‘u’,
‘cal_user_id’ => $user_id,
      foreach ($this->db->select($this->user_table,'cal_recur_date,cal_status',$where,
@@ -1370,7 +1387,7 @@
foreach ($this->db->select($this->user_table,‘DISTINCT cal_user_type,cal_user_id’, $where,
LINE,FILE,false,’’,‘calendar’) as $row)
  •   	$uid = $this->combine_user($row['cal_user_type'], $row['cal_user_id']);
  •   	$uid = self::combine_user($row['cal_user_type'], $row['cal_user_id']);
      	$id = $row['cal_user_type'] . $row['cal_user_id'];
      	$participants[$id]['type'] = $row['cal_user_type'];
      	$participants[$id]['id'] = $row['cal_user_id'];
@@ -1411,10 +1428,12 @@
* @param array $event Recurring Event.
* @param int servertime=0 == 0 -> export event with UTC timestamps
* != 0 -> export with servertime timestamps
    • @return array Array of exception days (false for non-recurring events).
  • function get_recurrence_exceptions(&$event, $servertime=0)
  • function get_recurrence_exceptions(&$event, $servertime=0, $start=0, $end=0)
    $cal_id = (int) $event[‘id’];
    if (!$cal_id || $event[‘recur_type’] == MCAL_RECUR_NONE) return false;
    @@ -1431,7 +1450,7 @@
    case ‘u’: // account
    case ‘c’: // contact
    case ‘e’: // email address
  •   			$recurrences = $this->get_recurrences($event['id'], $uid);
  •   			$recurrences = $this->get_recurrences($event['id'], $uid, $start, $end);
      			foreach ($recurrences as $recur_date => $recur_status)
      				if ($recur_date && $recur_status != $recurrences[0])
Modified: branches/1.6/phpgwapi/inc/horde/Horde/SyncML/Sync/TwoWaySync.php
URL: http://www.egroupware.org/viewvc/egroupware/branches/1.6/phpgwapi/inc/horde/Horde/SyncML/Sync/TwoWaySync.php?rev=28623&r1=28622&r2=28623&view=diff
— branches/1.6/phpgwapi/inc/horde/Horde/SyncML/Sync/TwoWaySync.php (original)
+++ branches/1.6/phpgwapi/inc/horde/Horde/SyncML/Sync/TwoWaySync.php Sun Nov 29 21:59:52 2009
@@ -423,15 +423,28 @@
‘type’ => $syncType,
‘filter’ => $this->_filterExpression
  •   $state->mergeChangedItems($syncType, $registry->call($hordeType . '/listBy', array (
  •   $changedItems =& $registry->call($hordeType . '/listBy', array (
      	'action' => 'modify',
      	'timestamp' => $refts,
      	'type' => $syncType,
      	'filter' => $this->_filterExpression
  •   Horde :: logMessage("SyncML: reading deleted items from database for $hordeType",
  •   	__FILE__, __LINE__, PEAR_LOG_DEBUG);
  •   $addedItems =& $registry->call($hordeType . '/listBy', array (
  •   	'action' => 'add',
  •   	'timestamp' => $refts,
  •   	'type' => $syncType,
  •   	'filter' => $this->_filterExpression
  •   // added items may show up as changed, too
  •   $changedItems = array_diff($changedItems, $addedItems);
  •   $state->mergeChangedItems($syncType, $changedItems);
  •   $state->mergeAddedItems($syncType, $addedItems);
  •   $state->setDeletedItems($syncType, $registry->call($hordeType . '/listBy', array (
      	'action' => 'delete',
@@ -439,8 +452,6 @@
  •   Horde :: logMessage("SyncML: reading added items from database for $hordeType",
      /* The items, which now match the filter criteria are show here, too
      $delta_add = count($registry->call($hordeType . '/listBy', array (
      	'action' => 'add',
@@ -449,12 +460,6 @@
  •   $state->mergeAddedItems($syncType, $registry->call($hordeType . '/listBy', array (
      $this->_syncDataLoaded = TRUE;
Modified: branches/1.6/syncml/calendar/lib/api.php
URL: http://www.egroupware.org/viewvc/egroupware/branches/1.6/syncml/calendar/lib/api.php?rev=28623&r1=28622&r2=28623&view=diff
— branches/1.6/syncml/calendar/lib/api.php (original)
+++ branches/1.6/syncml/calendar/lib/api.php Sun Nov 29 21:59:52 2009
@@ -69,7 +69,31 @@
$vcal = new Horde_iCalendar;
$boCalendar = new calendar_bo();
  • $show_rejected = $GLOBALS[‘egw_info’][‘user’][‘preferences’][‘calendar’][‘show_rejected’];
  • if (isset($GLOBALS[‘egw_info’][‘user’][‘preferences’][‘syncml’][‘calendar_filter’]))
  •   $syncCriteria = $GLOBALS['egw_info']['user']['preferences']['syncml']['calendar_filter'] ? 'all' : '';
  • } else {
  •   $syncCriteria = '';
  • $calendarOwner = $GLOBALS[‘egw_info’][‘user’][‘account_id’];
  • if (isset($GLOBALS[‘egw_info’][‘user’][‘preferences’][‘syncml’][‘calendar_owner’]))
  •   foreach($boCalendar->list_cals() as $grant)
  •   		if ($grant['grantor'] == $owner)
  •   			$calendarOwner = $owner;
  •   			break;
  • Horde::logMessage(“SymcML: egwcalendarsync calendar owner: $calendarOwner”,
    $now = time();
@@ -102,10 +126,12 @@
‘start’ => date(‘Ymd’, $startDate),
‘end’ => date(‘Ymd’, $endDate),
  •   'filter'  => $show_rejected ? 'all' : '',
  •   'filter'  => $syncCriteria,
  •   'users'   => $calendarOwner,
      'daywise' => false,
      'enum_recuring' => false,
      'enum_groups' => true,
  •   'cols'		=> array('egw_cal.cal_id', 'cal_start', 'recur_type'),
    $state = &$_SESSION[‘SyncML.state’];
    @@ -119,13 +145,15 @@
    $events =& $boCalendar->search($searchFilter);
  • foreach ((array)$events as $event)
  •   $guids[] = $guid = 'calendar-' . $event['id'];
  • foreach ($events as $event)
  •   $guids[] = $guid = 'calendar-' . $event['cal_id'];
      if ($event['recur_type'] != MCAL_RECUR_NONE)
  •   	$event['id'] = $event['cal_id'];
  •   	$event['start'] = $event['cal_start'];
      	// Check if the stati for all participants are identical for all recurrences
  •   	$days = $boCalendar->so->get_recurrence_exceptions(&$event, $tz_id);
  •   	$days = $boCalendar->so->get_recurrence_exceptions(&$event, $tz_id, $startDate, $endDate);
      	foreach ($days as $recur_date)
@@ -163,7 +191,7 @@
case ‘delete’ :
// filters may have changed, so we need to calculate which
// items are to delete from client because they are not longer in the list.
  •   	return $allChangedItems + array_diff($allClientItems, $allReadAbleItems);
  •   	return array_unique($allChangedItems + array_diff($allClientItems, $allReadAbleItems));
      case 'add' :
      	// - added items may not need to be added, cause they are filtered out.
Modified: branches/1.6/syncml/contacts/lib/api.php
URL: http://www.egroupware.org/viewvc/egroupware/branches/1.6/syncml/contacts/lib/api.php?rev=28623&r1=28622&r2=28623&view=diff
— branches/1.6/syncml/contacts/lib/api.php (original)
+++ branches/1.6/syncml/contacts/lib/api.php Sun Nov 29 21:59:52 2009
@@ -131,7 +131,7 @@
case ‘delete’ :
      case 'add' :
Modified: branches/1.6/syncml/inc/class.syncml_hooks.inc.php
URL: http://www.egroupware.org/viewvc/egroupware/branches/1.6/syncml/inc/class.syncml_hooks.inc.php?rev=28623&r1=28622&r2=28623&view=diff
— branches/1.6/syncml/inc/class.syncml_hooks.inc.php (original)
+++ branches/1.6/syncml/inc/class.syncml_hooks.inc.php Sun Nov 29 21:59:52 2009
@@ -31,8 +31,8 @@
	$selectYesNo = array(
  •   	0 => lang('no'),
  •   	1 => lang('yes')
  •   	1 => lang('Yes'),
  •   	0 => lang('No')
      $devices_Entries = array();
@@ -51,6 +51,14 @@
// list the InfoLog filters
$infolog_bo = new infolog_bo();
$show_infolog_filters = $infolog_bo->filters;
  •   // list the calendars this user has access to
  •   $calendar_bo = new calendar_bo();
  •   $show_calendars = array();
  •   foreach($calendar_bo->list_cals() as $grant)
  •   	$show_calendars[$grant['grantor']] = $grant['name'];
      // list the calendar categories of this user
      $categories = new categories($user, 'calendar');
@@ -96,7 +104,7 @@
‘xmlrpc’ => False,
‘admin’ => False
  •   		$me_name => array (
  •   		$me_name => array(
      			'type'		=> 'input',
      			'label'		=> 'Max Entries',
      			'name'		=> $me_name,
@@ -482,11 +490,11 @@
‘calendarhistoryintro’ => array(
‘type’ => ‘subsection’,
  •   		'title' => '<h3>' . lang('Calendar Synchronization Period') . '</h3>',
  •   		'xmlrpc' => False,
  •   		'admin'  => False
  •   	'calendar_past' => array (
  •   		'title' => '<h3>' . lang('Calendar Synchronization Options') . '</h3>',
  •   		'admin'  => False
  •   	'calendar_past' => array(
      		'type'		=> 'input',
      		'label'		=> lang('Calendar History Period'),
      		'name'		=> 'calendar_past',
@@ -497,7 +505,7 @@
‘xmlrpc’ => True,
‘admin’ => False,
  •   	'calendar_future' => array (
  •   	'calendar_future' => array(
      		'type'		=> 'input',
      		'label'		=> lang('Calendar Future Period'),
      		'name'		=> 'calendar_future',
@@ -507,6 +515,26 @@
‘default’ => 65000000,
‘xmlrpc’ => True,
‘admin’ => False,
  •   	'calendar_filter' => array(
  •   		'type'		=> 'select',
  •   		'label' 	=> 'Synchronize invitations you rejected',
  •   		'name'		=> 'calendar_filter',
  •   		'help'		=> lang('Should invitations you rejected still be synchronized to your devices?'),
  •   		'values'	=> $selectYesNo,
  •   		'default'	=> 0,
  •   		'xmlrpc'	 => True,
  •   		'admin'  	=> False,
  •   	'calendar_owner' => array(
  •   		'label' 	=> 'Syncronization Calendars',
  •   		'name'		=> 'calendar_owner',
  •   		'help'		=> lang('Events from all selected Calendars will be synchronized.'),
  •   		'values'	=> $show_calendars,
  •   		'default'	=> 'none',
  •   		'xmlrpc'	 => True,
  •   		'admin'  	=> False,
      	'taskoptionintro' => array(
      		'type'  => 'subsection',
Modified: branches/1.6/syncml/notes/lib/api.php
URL: http://www.egroupware.org/viewvc/egroupware/branches/1.6/syncml/notes/lib/api.php?rev=28623&r1=28622&r2=28623&view=diff
— branches/1.6/syncml/notes/lib/api.php (original)
+++ branches/1.6/syncml/notes/lib/api.php Sun Nov 29 21:59:52 2009
@@ -82,6 +82,7 @@
‘col_filter’ => array(
‘info_type’ => ‘note’,
  •   'col'		=> array('info_id'),
    $notes =& $boInfolog->search($searchFilter);
    @@ -123,7 +124,7 @@
    case ‘delete’ :
      case 'add' :
Modified: branches/1.6/syncml/tasks/lib/api.php
URL: http://www.egroupware.org/viewvc/egroupware/branches/1.6/syncml/tasks/lib/api.php?rev=28623&r1=28622&r2=28623&view=diff
— branches/1.6/syncml/tasks/lib/api.php (original)
+++ branches/1.6/syncml/tasks/lib/api.php Sun Nov 29 21:59:52 2009
@@ -83,6 +83,7 @@
‘info_type’ => ‘task’,
    $tasks =& $boInfolog->search($searchFilter);
    @@ -124,7 +125,7 @@
    case ‘delete’ :
      case 'add' :
eGroupWare-cvs mailing list
