Author: jlehrke
New Revision: 28337
URL: http://www.egroupware.org/viewvc/egroupware?rev=28337&view=rev
Add additional datastores
trunk/phpgwapi/inc/horde/Horde/SyncML/Command/Get.php
trunk/phpgwapi/inc/horde/Horde/SyncML/Command/Put.php
trunk/phpgwapi/inc/horde/Horde/SyncML/State.php
trunk/syncml/inc/class.syncml_hooks.inc.php
Modified: trunk/phpgwapi/inc/horde/Horde/SyncML/Command/Get.php
URL: http://www.egroupware.org/viewvc/egroupware/trunk/phpgwapi/inc/horde/Horde/SyncML/Command/Get.php?rev=28337&r1=28336&r2=28337&view=diff
— trunk/phpgwapi/inc/horde/Horde/SyncML/Command/Get.php (original)
+++ trunk/phpgwapi/inc/horde/Horde/SyncML/Command/Get.php Tue Nov 17 08:13:21 2009
@@ -106,7 +106,11 @@
array(‘text/plain’ => ‘1.0’));
$this->_writeDataStore(’./contacts’, ‘text/vcard’, ‘3.0’, $output,
array(‘text/x-vcard’ => ‘2.1’));
$this->_writeDataStore('./card', 'text/vcard', '3.0', $output, -
array('text/x-vcard' => '2.1')); $this->_writeDataStore('./tasks', 'text/calendar', '2.0', $output, -
array('text/x-vcalendar' => '1.0')); -
$this->_writeDataStore('./jobs', 'text/calendar', '2.0', $output, array('text/x-vcalendar' => '1.0')); $this->_writeDataStore('./calendar', 'text/calendar', '2.0', $output, array('text/x-vcalendar' => '1.0'));
Modified: trunk/phpgwapi/inc/horde/Horde/SyncML/Command/Put.php
URL: http://www.egroupware.org/viewvc/egroupware/trunk/phpgwapi/inc/horde/Horde/SyncML/Command/Put.php?rev=28337&r1=28336&r2=28337&view=diff
— trunk/phpgwapi/inc/horde/Horde/SyncML/Command/Put.php (original)
+++ trunk/phpgwapi/inc/horde/Horde/SyncML/Command/Put.php Tue Nov 17 08:13:21 2009
@@ -159,6 +159,7 @@
switch ($this->_sourceReference)
case ‘contact’:
case 'card': if ($this->_contentType != "text/x-s4j-sifc") { error_log("forcing 'contact' content type to 'text/x-s4j-sifc' instead of '".$this->_contentType."'");
Modified: trunk/phpgwapi/inc/horde/Horde/SyncML/State.php
URL: http://www.egroupware.org/viewvc/egroupware/trunk/phpgwapi/inc/horde/Horde/SyncML/State.php?rev=28337&r1=28336&r2=28337&view=diff
— trunk/phpgwapi/inc/horde/Horde/SyncML/State.php (original)
+++ trunk/phpgwapi/inc/horde/Horde/SyncML/State.php Tue Nov 17 08:13:21 2009
@@ -153,17 +153,17 @@
define(‘SERVER_SYNC_ACKNOWLEDGED’, 6);
// conflict management
-define(‘CONFLICT_CLIENT_WINNING’, 0);
-define(‘CONFLICT_SERVER_WINNING’, 1);
-define(‘CONFLICT_MERGE_DATA’, 2);
+define(‘CONFLICT_CLIENT_WINNING’, 0);
+define(‘CONFLICT_SERVER_WINNING’, 1);
+define(‘CONFLICT_MERGE_DATA’, 2);
define(‘CONFLICT_RESOLVED_WITH_DUPLICATE’, 3);
define(‘CONFLICT_CLIENT_CHANGES_IGNORED’, 4);
define(‘CONFLICT_CLIENT_REFRESH_ENFORCED’, 5);
define(‘MAX_DATA’, 19);
-define(‘MAX_ENTRIES’, 10); // default
-define(‘MAX_GUID_SIZE’, 64);
-define(‘MIN_MSG_LEFT’, 200); // Overhead
+define(‘MAX_ENTRIES’, 10); // default
+define(‘MAX_GUID_SIZE’, 64);
+define(‘MIN_MSG_LEFT’, 200); // Overhead
- The Horde_SyncML_State class provides a SyncML state object.
@@ -846,6 +846,7 @@
$_type = str_replace(’./’,’’,$type);
switch (strtolower($_type)) {
case ‘contacts’:
case 'card': return 'text/vcard'; break;
@@ -856,6 +857,7 @@
case ‘calendar’:
case ‘events’:
case ‘tasks’:
case 'jobs': case 'caltasks': return 'text/calendar'; break;
@@ -892,6 +894,7 @@
switch(strtolower($_type))
case ‘contacts’:
case 'card': return 'contacts'; break;
@@ -900,6 +903,7 @@
break;
case 'tasks':
case 'jobs': return 'tasks'; break;
Modified: trunk/syncml/inc/class.syncml_hooks.inc.php
URL: http://www.egroupware.org/viewvc/egroupware/trunk/syncml/inc/class.syncml_hooks.inc.php?rev=28337&r1=28336&r2=28337&view=diff
— trunk/syncml/inc/class.syncml_hooks.inc.php (original)
+++ trunk/syncml/inc/class.syncml_hooks.inc.php Tue Nov 17 08:13:21 2009
@@ -205,6 +205,24 @@
‘admin’ => False,
‘default’ => 1
'./card' => array( -
'type' => 'select', -
'label' => './card', -
'name' => './card', -
'values' => $show_entries, -
'xmlrpc' => True, -
'admin' => False, -
'default' => 1 -
'card' => array( -
'label' => 'card', -
'name' => 'card', -
'xmlrpc' => True, -
'admin' => False, -
'default' => 1 -
), './tasks' => array( 'type' => 'select', 'label' => './tasks',
@@ -223,6 +241,24 @@
‘admin’ => False,
‘default’ => 1
'./jobs' => array( -
'label' => './jobs', -
'name' => './jobs', -
'xmlrpc' => True, -
'admin' => False, -
'default' => 1 -
'jobs' => array( -
'label' => 'jobs', -
'name' => 'jobs', -
'xmlrpc' => True, -
'admin' => False, -
'default' => 1 -
), './caltasks' => array( 'type' => 'select', 'label' => './caltasks',
@@ -344,6 +380,24 @@
‘type’ => ‘select’,
‘label’ => ‘siftasks’,
‘name’ => ‘siftasks’,
'xmlrpc' => True, -
'admin' => False, -
'default' => 1 -
'./stask' => array( -
'label' => './stask', -
'name' => './stask', -
'xmlrpc' => True, -
'admin' => False, -
'default' => 1 -
'stask' => array( -
'label' => 'stask', -
'name' => 'stask', 'values' => $show_entries, 'xmlrpc' => True, 'admin' => False,
eGroupWare-cvs mailing list
