Author: ralfbecker
New Revision: 25071
URL: http://www.egroupware.org/viewvc?rev=3D25071&view=3Drev
allow to use global db-object (and no clone&set_app), if told so via a sepa=
rate parameter to the constructor (not by default as the app using so_sql m=
ight not be ready for it)
trunk/etemplate/inc/class.so_sql.inc.php
Modified: trunk/etemplate/inc/class.so_sql.inc.php
URL: http://www.egroupware.org/viewvc/trunk/etemplate/inc/class.so_sql.inc.=
php?rev=3D25071&r1=3D25070&r2=3D25071&view=3Ddiff
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
=3D=3D=3D
— trunk/etemplate/inc/class.so_sql.inc.php (original)
+++ trunk/etemplate/inc/class.so_sql.inc.php Thu Mar 13 12:08:54 2008
@@ -6,6 +6,7 @@
- @package etemplate
- @link http://www.egroupware.org
- @author Ralf Becker RalfBecker@outdoor-training.de
- @copyright 2002-8 by RalfBecker@outdoor-training.de
@version $Id$
@@ -61,11 +62,11 @@
var $total =3D false;
- privat instance of the db-object
protected instance or reference (depeding on $no_clone param of constr=
uctor) of the db-object -
@var egw_db
- var $db;
- protected $db;
/**- unique keys/index, set by derived class or via so_sql($app,$table)
@@ -94,6 +95,12 @@
* @var array
var $table_def =3D array();
- Appname to use in all queries, set via constructor
- @var string
- var $app;
/**- holds the content of all columns
@@ -129,17 +136,28 @@
* @param string $table should be set if table-defs to be read from =
/setup/tables_current.inc.php
* @param object/db $db database object, if not the one in $GLOBALS[‘egw’=
]->db should be used, eg. for an other database
* @param string $colum_prefix=3D’’ column prefix to automatic remove fro=
m the column-name, if the column name starts with it
- @param boolean $no_clone=3Dfalse can we avoid to clone the db-object, =
default no =
new code using appnames and foreach(select(…,$app) can set it to av=
oid an extra instance of the db object -
@return so_sql
- function so_sql($app=3D’’,$table=3D’’,$db=3Dnull,$column_prefix=3D’’)
$this->db =3D is_object($db) ? clone($db) : clone($GLOBALS['egw']->db);
- function so_sql($app=3D’’,$table=3D’’,$db=3Dnull,$column_prefix=3D’’,$no_=
clone=3Dfalse) - {
if ($no_clone) -
$this->db =3D is_object($db) ? $db : $GLOBALS['egw']->db; -
else -
$this->db =3D is_object($db) ? clone($db) : clone($GLOBALS['egw']->db); -
} $this->db_cols =3D $this->db_key_cols + $this->db_data_cols;
if ($app)
$this->db->set_app($app);
$this->app =3D $app; -
if (!$no_clone) $this->db->set_app($app);
if ($table) $this->setup_table($app,$table,$column_prefix);
@@ -369,41 +387,39 @@
unset($query[$col]);
$this->db->select($this->table_name,'*'.($extra_cols?','.(is_array($extr=
a_cols)?implode(’,’,$extra_cols):$extra_cols):’’),
$query,__LINE__,__FILE__,False,'',False,0,$join); -
if (!($row =3D $this->db->row(true))) -
if ($this->autoinc_id) -
unset($this->data[$this->db_key_cols[$this->autoinc_id]]); -
if ((int) $this->debug >=3D 4) echo "nothing found !!!</p>\n";
foreach($this->db->select($this->table_name,'*'.($extra_cols?','.(is_arr=
ay($extra_cols)?implode(’,’,$extra_cols):$extra_cols):’’),
$query,__LINE__,__FILE__,False,'',$this->app,0,$join) as $row) -
$cols =3D $this->db_cols; -
if ($extra_cols) // extra columns to report -
foreach(is_array($extra_cols) ? $extra_cols : array($extra_cols) as $c=
ol)
if (FALSE!=3D=3Dstripos($col,' as ')) $col =3D preg_replace('/^.* as =
*([a-z0-9_]+) *$/i’,’\1’,$col);
$cols[$col] =3D $col; -
foreach ($cols as $db_col =3D> $col) -
$this->data[$col] =3D $row[$db_col]; -
} $this->db2data();
return False; -
foreach(is_array($extra_cols) ? $extra_cols : array($extra_cols) as $co=
l)
if (FALSE!=3D=3Dstripos($col,' as ')) $col =3D preg_replace('/^.* as *=
if ((int) $this->debug >=3D 4) -
echo "data =3D\n"; _debug_array($this->data); -
return $this->data; -
if ((int) $this->debug >=3D 4) echo "nothing found !!!</p>\n"; -
$this->db2data();
return $this->data;
return False;}
@@ -435,7 +451,7 @@
$data[$db_col] =3D (string) $this->data[$col] =3D=3D=3D ‘’ && $this->=
empty_on_write =3D=3D ‘NULL’ ? null : $this->data[$col];
$this->db->insert($this->table_name,$data,false,__LINE__,__FILE__);
$this->db->insert($this->table_name,$data,false,__LINE__,__FILE__,$this=
->app);
@@ -478,11 +494,11 @@
if (!$this->autoinc_id) // always try an insert if we have no autoinc_i=
d, as we dont know if the data exists
$this->db->insert($this->table_name,$data,$keys,__LINE__,__FILE__);
$this->db->insert($this->table_name,$data,$keys,__LINE__,__FILE__,$thi=
s->app);
else
$this->db->update($this->table_name,$data,$keys,__LINE__,__FILE__);
$this->db->update($this->table_name,$data,$keys,__LINE__,__FILE__,$thi=
s->app);
$this->db2data();
@@ -554,7 +570,7 @@
$query[$db_col] =3D $data[$col];
$this->db->delete($this->table_name,$query,__LINE__,__FILE__);
$this->db->delete($this->table_name,$query,__LINE__,__FILE__,$this->app);
return $this->db->affected_rows();
@@ -620,8 +636,16 @@
list($table,$only_col) =3D explode(’.’,$db_col);
$table_def =3D $this->db->get_table_definitions(true,$table);
$query[] =3D $db_col.(is_array($val) ? ' IN ' : '=3D').$this->db->qu=
ote($val,$table_def[‘fd’][$only_col]);
if (is_array($val) && count($val) > 1) -
array_walk($val,array($this->db,'quote'),$table_def['fd'][$only_col=
][‘type’]);
$query[] =3D $sql =3D $db_col.' IN (' .implode(',',$val).')'; -
else -
$query[] =3D $db_col.'=3D'.$this->db->quote(is_array($val)?array_sh=
ift($val):$val,$table_def[‘fd’][$only_col][‘type’]);
} } else {
@@ -739,11 +763,10 @@
else // cant do a count, have to run the query without limit
$this->db->union($union,__LINE__,__FILE__); -
$this->total =3D $this->db->num_rows(); -
$this->db->union($union,__LINE__,__FILE__,$order_by,$start,$num_rows);
$this->total =3D $this->db->union($union,__LINE__,__FILE__)->NumRows(=
$rs =3D $this->db->union($union,__LINE__,__FILE__,$order_by,$start,$num=
_rows);
$cols =3D $union_cols;
$union =3D $union_cols =3D array();
@@ -758,17 +781,15 @@
elseif (!$need_full_no_count && (!$join || stripos($join,‘LEFT JOIN’)!=
=3D=3Dfalse))
$this->db->select($this->table_name,'COUNT(*)',$query,__LINE__,__FILE=
__,false,’’,false,0,$join);
$this->total =3D $this->db->next_record() ? (int) $this->db->f(0) : f=
alse;
$this->total =3D $this->db->select($this->table_name,'COUNT(*)',$quer=
y,LINE,FILE,false,’’,$this->app,0,$join)->fetchSingle();
$this->db->select($this->table_name,$colums,$query,__LINE__,__FILE__,=
false,$order_by,false,0,$join);
$this->db->select($this->table_name,$mysql_calc_rows.$colums,$query,__L=
INE__,FILE,
$start,$order_by,false,$num_rows,$join);
$this->total =3D $this->db->select($this->table_name,$colums,$query,_=
LINE_,FILE,false,$order_by,false,0,$join)->NumRows();
$rs =3D $this->db->select($this->table_name,$mysql_calc_rows.$colums,$q=
uery,LINE,FILE,
$start,$order_by,$this->app,$num_rows,$join);
$cols =3D $this->_get_columns($only_keys,$extra_cols);
@@ -776,10 +797,10 @@
if ($mysql_calc_rows)
$this->total =3D $this->db->Link_ID->GetOne('SELECT FOUND_ROWS()');
$this->total =3D $this->db->query('SELECT FOUND_ROWS()')->fetchSingle(); } $arr =3D array();
for ($n =3D 0; ($row =3D $this->db->row(true)); ++$n)
if ($rs) foreach($rs as $row) { $data =3D array(); foreach($cols as $db_col =3D> $col)
@@ -787,6 +808,7 @@
$data[$col] =3D $row[$db_col];
$arr[] =3D $this->db2data($data);
}$n++; } return $n ? $arr : False;
@@ -857,9 +879,10 @@-
@param string $join=3D’’ sql to do a join, added as is after the table=
-name, eg. “, table2 WHERE x=3Dy” or = -
“LEFT JOIN table2 ON (x=3Dy)”, Note: there’s no quoting done on $join!
@param boolean $need_full_no_count=3Dfalse If true an unlimited query =
is run to determine the total number of rows, default false
- @param mixed $only_keys=3Dfalse, see search
- @return int total number of rows
- function get_rows($query,&$rows,&$readonlys,$join=3D’’,$need_full_no_coun=
t=3Dfalse)
t=3Dfalse,$only_keys=3Dfalse)
@@ -873,7 +896,7 @@
$criteria[$col] =3D $query[‘search’];
$rows =3D $this->search($criteria,false,$query['order']?$query['order'].=
’ ‘.$query[‘sort’]:’’,
$rows =3D $this->search($criteria,$only_keys,$query['order']?$query['ord=
er’].’ ‘.$query[‘sort’]:’’,
’’,’%’,false,‘OR’,$query[‘num_rows’]?array((int)$query[‘start’],$query[=
‘num_rows’]):(int)$query[‘start’],
$query[‘col_filter’],$join,$need_full_no_count);
@@ -977,14 +1000,3 @@
return $cache[$cache_key] =3D& $ret;
-if (!function_exists(“stripos”)) =
- stripos for php < 5
- function stripos($str,$needle,$offset=3D0)
return strpos(strtolower($str),strtolower($needle),$offset); - }
eGroupWare-cvs mailing list
