Newbie question: InfoLog or Knowledge Base?
I have some info that I’d like to store that is only valid for a small number of users, while there are other pieces of info that should be able to be accessed by a greater number of users/all. Should I be using Knowledge Base or InfoLog? If so, how should I be applying the ACL’s to make this work. Thanks in advance.
I believe infolog is more versatile.
To apply ACL’s, click on “GRANT ACCESS” in the control panel, on the left side.
Hello
If you use Infolog follow this instruction to set up ACL Rights.
  1. Step : Infolog type creation (In Custom Fields)
  2. Step : Put it into the group
  3. Step : Go in the admin module
  4. Step : Go in user groups et choose the group
  5. Step : Click in edit infolog (Permissions this group has)
  6. Step : Give the rights for Add and Edit.
  7. Step : Save
  8. Step : Submitt changes
Best Regards
Qualinnove Extensions Team
www.qualinnove.lu
Thanks for the responses. Perhaps I’m not representing myself properly … essentially I want to create multiple documents, each with different access. From the advice given, it seems that ACL’s would apply to ALL InfoLog notes that I create.
I don’t know so much about knowledge base, but it’s not possible with infolog.
And as nobody has replied, describing how to do it with kb, I would guess that it’s not possible there either.
I dont know in which area/way do you want use/create these documents. Eventually you can use MyDMS or News Admin.
Best Regards
www.qualinnove.lu
