Migration-upgrade issue with db
Hello,
I’m moving my EGW installation to a new server and taking the
opportunity to upgrade from 1.6002 to 1.8001.
Both old and new servers are running CentOS 5 and using Postgresql
8.1.22 as the db.
I’ve downloaded and installed all apps and EGW core RPMS as directed.
Everything installed fine, apps installed, db and tables all installed
and connecting fine. I’m able to log in, add a user and the user can log
in, see email, all good.
However, I’m having problems moving the data from the 1.6 installation
to 1.8. I’ve tried copying over a EGW db backup from 1.6 to the 1.8
backup folder and doing a db restore in 1.8. The restore appears to run
for a minute or so, says its’ done, but there is no data added to the db.
I’ve also tried a “pgdump” and import using psql. It appears to run OK,
but I do see some error statements flying by on the screen. When done, I
can see data has been added to the tables, using pgPHPadmin 4.2, except
for the “egw_accounts” table. It shows only 6 entries where the old 1.6
installation had 40+ accounts.
I’m thinking of dumping the “egw_accounts” table from 1.6, emptying the
"egw_accounts" table in 1.8 then restoring the data from 1.6. Is this a
good way to proceed? I’m afraid of all users loosing access to their
data in 1.8!
Any recommendations here appreciated!
Thanks.
Thomas E. Plancon
CAD/IS Manager
B K A Architects, Inc.
142 Crescent Street
Brockton, MA 02302
tel: 508 . 583 . 5603 ext 313
fax: 508 . 584 . 2914
www.bkaarchitects.com http://www.bkaarchs.com/
Update
It appears the DB structure for the table “egw_accounts” in 1.6 is not the same in 1.8. Specifically the table in 1.6 has 2 more fields than in 1.8: “account_challenge” and “account_response”.
When I dumped “egw_accounts” from 1.6 it showed the 2 extra fields always to be “null”. So I deleted the 2 extra fields from all entries in the dump and did an insert to the new 1.8 DB installation. It worked fine! All accounts appear to be in place and various users can log in.
Now I need to verify everyone’s permissions and access rights are the same in 1.8 as in 1.6.
Protect Your Site and Customers from Malware Attacks
Learn about various malware tactics and how to avoid them. Understand
malware threats, the impact they can have on your business, and how you
can protect your company and customers by using code signing.
http://p.sf.net/sfu/oracle-sfdevnl
When I did this recently I found the easiest way for me was to upgrade the old install to
1.8 then move it. The upgrade updated the databases so there was no problem moving them.
There was a glitch with updating the databases but it worked itself out.
Tom Plancon wrote:
Hello,
I’m moving my EGW installation to a new server and taking the opportunity to upgrade
Both old and new servers are running CentOS 5 and using Postgresql 8.1.22 as the db.
I’ve downloaded and installed all apps and EGW core RPMS as directed. Everything
installed fine, apps installed, db and tables all installed and connecting fine. I’m able to log
in, add a user and the user can log in, see email, all good.
However, I’m having problems moving the data from the 1.6 installation to 1.8. I’ve
tried copying over a EGW db backup from 1.6 to the 1.8 backup folder and doing a db restore in
1.8. The restore appears to run for a minute or so, says its’ done, but there is no data added to
the db.
I’ve also tried a “pgdump” and import using psql. It appears to run OK, but I do see some
error statements flying by on the screen. When done, I can see data has been added to the
tables, using pgPHPadmin 4.2, except for the “egw_accounts” table. It shows only 6 entries
where the old 1.6 installation had 40+ accounts.
"egw_accounts" table in 1.8 then restoring the data from 1.6. Is this a good way to proceed? I’m afraid of
all users loosing access to their data in 1.8!
Thanks.
myEMAILsignature Thomas E. Plancon
CAD/IS Manager
142 Crescent Street
Brockton, MA 02302
[www.bkaarchitects.com
https://lists.sourceforge.net/lists/listinfo/egroupware-users ->
http://www.bkaarchs.com/]
Signature Robert Steinmetz, AIA
Principal
Steinmetz & Associates
Thanks for the input. Sorry for the lag responding. I did end up upgrading EGW in place.
Everything seemed to work well except for Tracker. I kept getting errors in the “setup/Manage
applications” for tracker with the suggestion to remove and re-install. So I did and it blew away the
Tracker DB tables.
I have a backup of the tracker tables but they are in the 1.6 table format. I need to come up
with a method to update the data to the new format. More posts to the forum!
It is interesting to see an architect using egroupware. I’m the IT guy for a 40 person
architectural firm and slowly integrating egw into our workflow. Any input/suggestion would be
appreciated. I’m happy to share our experience.
Best wishes!
Thomas E. Plancon
CAD/IS Manager
BKA Architects, Inc.
142 Crescent St.
Brockton, MA 02302
The modern datacenter depends on network connectivity to access resources
and provide services. The best practices for maximizing a physical server’s
connectivity to a physical network are well understood - see how these
rules translate into the virtual world?
http://p.sf.net/sfu/oracle-sfdevnlfb
