I have two groups in my egw: operatorGroup and userGroup.
I want that the operatorGroup can share the files of a folder with the userGroup in this way:
- operatorGroup inserts files in a own created folder so it can see and modify the files in that folder
- userGroup can see that folder, can see all the files but can’t modify the folder and the files
I can’t find the solution to make this.
Thanks
From
http://www.egroupware.org/index.php?page_name=wiki&lang=&wikipage=FAQen :
1d. Can’t share files in filemanger
Filemanager does NOT support sharing of the home-directories of users!
If you want to share files, you need to use group-directories.
To do so, please follow these steps (loged in as an admin):
You have to create a group ACL: Admin >> Manage groups, choose the group
and click on the pencil icon behind filemanager: eg. you choose group
"Default" and give read+edit+delete for group Default.
Then you go to filemanager and go up one level up to /home, then the
Default group-dir will be created and from now on you will see it in the
list of directories, you can change to
Further notes
You don’t need to create any directory yourself, this causes only trouble! ###
hope this helps…
urodelo
the
Thanks
Creato con il rivoluzionario client e-mail di Opera:
http://www.opera.com/mail/
