Feature Requests #502: Next Match Widget & select sort headers
Ticket modified by Tracking System at 2010/12/18 12:03
Tracking System: Feature Requests
Category: eTemplate
Version: Version 1.4 (unsupported)
Status: Closed
Resolution: None
Completed: 0%
Priority: 5 - medium
Created By: randy houlahan
Assigned to: Ralf Becker
Summary: #502 - Next Match Widget & select sort headers
Preference to turn off auto search when selecting an option within the next macth widget and sort headers. Most searches we find take multiple selection of options. As a result we have to perform 3 seperate searchs to achieve one.
Suggestion: if diff options are selected only execute on the search button execution.
Comment by Tracking System at 2010/12/18 12:03:
Comment by Ralf Becker at 2010/12/04 11:38:
Dear EGroupware user,
thanks for reporting feature requests to egroupware.org.
With the new release of EGroupware 1.8.001 we implemented many new features. So we kindly ask you to recheck your feature request against the new version. If it is still valid, please reopen it with the current version 1.8.001.
If you do not respond within the next 14 days, we assume the request is no longer necessary and it will be closed automatically.
Thanks for your understanding
Comment by Ralf Becker at 2007/05/03 15:27:
we reset all priority to 5, which is the new initial state of tracker items. The priority can now only be changed by Tracker admins or the assigned developer. This allows the developers to manage their work with the priorities. Users can vote to articulate their priorities.
linked entries:
http://www.egroupware.org/egroupware/index.php?menuaction=tracker.tracker_ui.edit&tr_id=502&no_popup=1
