Ticket modified by camel camel at 2010/06/18 11:35
Tracking System: Feature Requests
Category: SyncML
Version: Trunk
Status: Closed
Resolution: None
Completed: 0%
Priority: 5 - medium
Created By: camel camel
Assigned to: Jörg Lehrke
Summary: #2636 - Default Settings for sync devices (specially time zone)
it would be fine, if there are default settings for default devices
(ex: some syncml clients - like Synthesis client need the sync-time set - otherwise it will sync the times for events wrong …
my workaround is now a little bit complicated…
1.) sync contacts (which is working also on first time)
2.) then i go to EGW - syncml settings and set the correct time zone)
3.) then i do the other items, which are time based - and then it is working correct …
Comment by camel camel at 2010/06/18 11:35:
close it, because made it more in detail on FR: #2661
linked entries:
http://www.egroupware.org/egroupware/index.php?menuaction=tracker.tracker_ui.edit&tr_id=2636&no_popup=1
