New ticket submitted by André Scholz at 2011/03/25 16:29
Tracking System: Bugs
Category: Timesheet
Version: Version 1.6 (unsupported)
Status: Open
Completed: 0%
Priority: 5 - medium
Created By: André Scholz
Created on: 2011/03/25 16:29
Assigned to: Ralf Becker
Summary: #2912 - timesheet analysis
Do You have the problem that You can’t say where all Your or Your workers time is gone?
I had the same problem. The summary of the time sheet is not exact enought to say where the problem is.
That’s why I made this (very small ) extension for the time sheet.
You have to install it manually, I didn’t have the time & money to write an installation for this extension. You also have to add the name for who You want to controll the time sheet.
It doesn’t need a table in database, all the data comes is extracted from the time sheet database.
It is like in beta status, because You can’t constrain between two dates (maybe someone is interested in programming it).
linked entries:
http://www.egroupware.org/egroupware/index.php?menuaction=tracker.tracker_ui.edit&tr_id=2912&no_popup=1
