Bugs #2906: Calendar filter 'hideprivate' works like 'showonlypublic'
Ticket modified by Ralf Becker at 2011/03/22 06:09
Tracking System: Bugs
Category: Calendar
Version: Version 1.8.001
Status: Open
Resolution: None
Completed: 0%
Priority: 5 - medium
Created By: Philipp -
Created on: 2011/03/22 03:28
Assigned to: Nathan Gray
Summary: #2906 - Calendar filter ‘hideprivate’ works like 'showonlypublic’
Dear Developers!
About two months ago I used the ‘hideprivate’ filter to print out my calendar without private informations, but including the private events for blocking the time.
Now hideprivate works exactly like showonlypublic: Removing the private events completely from the calendar.
Tested with Opera and Firefox (both last Version)
EGroupware Version 1.8.001 (updates nightly per SVN)
PHP Version 5.3.3: apache2handler
Bug can be repeated in the Demo.
With kind regards,
Philipp
Comment by Ralf Becker at 2011/03/22 06:09:
Hi Nathan,
seems like the “filter” hideprivate is interpreted wrong. It should in fact return all events to bo and bo masks out the private information.
Can you have a look please.
linked entries:
http://www.egroupware.org/egroupware/index.php?menuaction=tracker.tracker_ui.edit&tr_id=2906&no_popup=1
