Bugs #2763: Exported Projects with Coordinator or Project Member reads "Array"
Ticket modified by Birgit Becker at 2010/12/15 17:14
Tracking System: Bugs
Category: ImportExport
Version: Version 1.8.001
Status: Pending
Resolution: Fixed
Completed: 80%
Priority: 5 - medium
Created By: Rubén Muñoz
Assigned to: not assigned
Summary: #2763 - Exported Projects with Coordinator or Project Member reads "Array"
We have noticed a possible issues that prevent us from getting the following functionality:
Export “Project Coordinator(s)” and the “Project Member(s)” associated with the "Project Title.
This can be reproduced in the Community Edition “Export icon” and in the EPL “import/export module”.
The result file follows:
pm_id pm_title pm_number pm_description Coordinator Accounting Assistant Projectmember
1 Test project P-2010-0001 Test description Array Array
Array should be “[coordinator] Coordinator, Coordinator” and “[member] Member, Member”
Thanks
Comment by Birgit Becker at 2010/12/15 17:14:
Hi Ruben,
its fixed in trunk and willbe backported as soon as possible
Birgit
Comment by Birgit Becker at 2010/12/10 22:35:
Hi Ruben,
tested that issue: it happens only if you selct in the profil, that you want to export the database-values instead of the "human friendly names".
I gave it to the developer to fix it.
Sorry for not answering earlier, but your mail where you refereed to that ticket gets "lost" in my mails and i just remembered your mail, when i looked in the egroupware.org tracker.
Birgit
linked entries:
http://www.egroupware.org/egroupware/index.php?menuaction=tracker.tracker_ui.edit&tr_id=2763&no_popup=1
