Ticket modified by Jörg Lehrke at 2010/09/25 11:23
Tracking System: Bugs
Category: Filemanager
Version: Version 1.6.003
Status: Closed
Resolution: Later
Completed: 100%
Priority: 5 - medium
Created By: lluís d
Assigned to: Jörg Lehrke
Summary: #2699 - Error 401 when i use webdav using netdrive/webdrive/bitkinex/cadaver…
This problem occurs in new community version. The problem is that try to connect to webdav but can not connect and finally says http error 401. But filemanager works great and webdav througt the firefox/explorer works great.
This problem occurs first about 2 months but only have 2 weeks duration, then works without doing nothing. Now 1-2 weeks ago dont work, and i dont know how to solve it and what happens? because i dont change anything. I use about 100gb of files/directories and a lot of ACL rights but i dont thing that is the problem.
ACCESS_LOG
“PROPFIND /egw/webdav.php/DATA/ HTTP/1.1” 401 - “-” “BitKinex/3.2.3” “-”
ERROR_LOG
webdav: explodeArray\n(\n [0] => \n [1] => DATA\n [2] => \n)\n
If anyone knows any solution? i restart apache but nothing… i dont know what happens.thanks
Comment by Jörg Lehrke at 2010/07/26 20:33:
This issue is maybe fixed in the Trunk version. You could use at least the egw-pear stuff and webdav.php from SVN to fix it for your instance, too.
linked entries:
http://www.egroupware.org/egroupware/index.php?menuaction=tracker.tracker_ui.edit&tr_id=2699&no_popup=1
