Bugs #2651: changing between different mailaccounts doesn't work
Ticket modified by Stefan Roder at 2010/06/11 16:03
Tracking System: Bugs
Category: FelamiMail
Version: Trunk
Status: Open
Resolution: None
Completed: 0%
Priority: 5 - medium
Created By: Stefan Roder
Assigned to: Klaus Leithoff
Summary: #2651 - changing between different mailaccounts doesn’t work
Hi Klaus,
I cannot change from one mailidentity to another one. This happened some revision before and had to do with the xajax component (if I’m not completely wrong). I know, that there’s of work going on at the moment - this is just to inform you.
Greetings from hamburg,
Comment by Stefan Roder at 2010/06/11 16:03:
It’s enabled and shows ver 1.2.1
Comment by Ralf Becker at 2010/06/11 15:50:
Admin >> phpinfo should show "json" as "enabled".
Comment by Stefan Roder at 2010/06/11 15:45:
the module is installed - do I have to enable it seperately?
Comment by Klaus Leithoff at 2010/06/11 15:23:
is your json support enabled.
Comment by Stefan Roder at 2010/06/11 10:11:
Removed xajax.php - no effect! Problem remains.
Comment by Klaus Leithoff at 2010/06/11 09:31:
Hmmm, tested that just now.
It is working for me.
maybe its a thing with the xajax.php It has been removed from trunk.
If it is still there it may cause problems.
linked entries:
http://www.egroupware.org/egroupware/index.php?menuaction=tracker.tracker_ui.edit&tr_id=2651&no_popup=1
