Bugs #2537: keine Geburtstage auf im Home (27503-27553)
Ticket modified by da ku at 2010/05/05 05:52
Tracking System: Bugs
Category: Addressbook
Version: Trunk
Status: Closed
Resolution: None
Completed: 0%
Priority: 5 - medium
Created By: da ku
Assigned to: Nathan Gray
Summary: #2537 - keine Geburtstage auf im Home (27503-27553)
Moin.
Habe heute das Trunk 27553 eingespielt und es werden keine Geburtstage mehr im Home angezeigt, in der 27053 ging noch alles.
MfG
Comment by da ku at 2010/05/05 05:52:
sry for late reply
here, i’ve found the solution:
http://egroupware.219119.n3.nabble.com/Adresbuchfehler-bei-SVN-checkout-auf-trunk-29774-tp715738p715738.html
There are different types of Function arguments and arrays had not worked at this moment you changed addressbook_so to extend so_sql_cf (r29739)
Comment by Nathan Gray at 2010/04/21 09:50:
Is this still an issue?
Linked entries:
http://www.egroupware.org/egroupware/index.php?menuaction=tracker.tracker_ui.edit&tr_id=2537&no_popup=1
