Ticket modified by Tracking System at 2010/12/17 18:02
Tracking System: Bugs
Category: Tracker
Version: Version 1.6 (unsupported)
Status: Closed
Resolution: None
Completed: 0%
Priority: 5 - medium
Created By: Peter Tuhársky
Assigned to: Ralf Becker
Summary: #2183 - Settings - Close pending - dosen’t respect 'Never’
There is an option in Site settings - Configuration - named Close ‘pending’. If I select some available value (1-30), it works. However, if I select the value ‘Never’, after saving the settings the value is reverted to default ‘7’.
Comment by Tracking System at 2010/12/17 18:02:
Comment by Ralf Becker at 2010/12/03 17:49:
Dear EGroupware user,
Thanks for your understanding
Comment by Stefan Roder at 2010/01/27 00:02:
The same appears in our installation. This is very urgent, as we do not want to allow to close tickets without a solution. Are there any workarounds out there?
linked entries:
http://www.egroupware.org/egroupware/index.php?menuaction=tracker.tracker_ui.edit&tr_id=2183&no_popup=1
