Bugs #1831: PostgreSQL 8.1: index error when importing manual from egroupware.org
Ticket modified by Ralf Becker at 2010/12/03 23:53
Tracking System: Bugs
Category: Manual
Version: Trunk
Status: Pending
Resolution: Fixed
Completed: 0%
Priority: 5 - medium
Created By: Yudhi Kusnanto
Assigned to: Ralf Becker
Summary: #1831 - PostgreSQL 8.1: index error when importing manual from egroupware.org
when i click admin->manual->import, processing stop with error when an entry contain large row. the message i reproduce is like this:
SQL error:
ERROR: index row size 3596 exceeds btree maximum, 2713
HINT: Values larger than 1/3 of a buffer page cannot be indexed.
Consider a function index of an MD5 hash of the value, or use full text indexing.
In statement:
CREATE INDEX “egw_wiki_pages_body” ON “egw_wiki_pages” USING BTREE (“wiki_body”)
this index is new compare to 1.4.x.
after deleting and recreate the index using HASH, importing manual continue successfully.
ADDITIONAL INFO:
egw-trunk: rev. 26335
db: Postgresql 8.1
php: v5.1.x
apache: v2.2x
Comment by Ralf Becker at 2010/12/03 23:53:
Dear EGroupware user,
Thanks for your understanding
Comment by Yudhi Kusnanto at 2008/11/14 04:28:
this bug is re-open because it’s still present on new installation using trunk rev.26364.
additional info:
eGroupWare API version 1.5.017 (svn trunk r.26364)
Manual/Help version 1.6
Error log is attached.
Comment by Ralf Becker at 2008/11/13 18:35:
problem should be fixed with svn revision r26299 for newly created databases:
http://www.egroupware.org/viewvc?view=rev&revision=26299
Before indexes were created for longtext column. Now we only create MySQL Fulltext indexes for text and longtext, and non for any other database.
Please test again with a new install and re-open if the problem persists.
linked entries:
http://www.egroupware.org/egroupware/index.php?menuaction=tracker.tracker_ui.edit&tr_id=1831&no_popup=1
