Bugs #1679: Projectmanager -Unable to add existing Tracker issue
Ticket modified by Peter Tuhársky at 2010/12/21 14:08
Tracking System: Bugs
Category: Projectmanager
Version: Version 1.8.001
Status: Open
Resolution: None
Completed: 0%
Priority: 5 - medium
Created By: Peter Tuhársky
Assigned to: Ralf Becker
Summary: #1679 - Projectmanager -Unable to add existing Tracker issue
Trying to add existing Tracker issue to the Project, the Search dosen’t display some items depending on their status. Seems, that only “open” tickets are searched.
Comment by Peter Tuhársky at 2010/12/21 14:08:
Still not working in 1.8
Comment by Tracking System at 2010/12/17 18:02:
Comment by Ralf Becker at 2010/12/03 17:49:
Dear EGroupware user,
Thanks for your understanding
Comment by Peter Tuhársky at 2009/06/10 15:41:
Still an issue… Only "open" trackers are searched. The tracker can have any other status, such as "pending", "worked on" etc…
Comment by Tracking System at 2008/11/28 15:25:
Comment by Ralf Becker at 2008/10/16 13:30:
Dear bug reporter,
we finished the first release candidate for the upcoming 1.6 release :slight_smile:
Therefore we kindly ask for your participation in fixing the remaining bugs. Please check if your reported bug is still present in the release candidate (report as 1.6.rc1) OR a newer svn checkout (report as Trunk).
If the bug still exists in 1.6.rc1 or Trunk, please update the version accordingly and indicate it in your comment.
If the bug does not exist in 1.6, but of cause still in 1.4, you can reopen it with version 1.4 - thought we probably don’t have the resources to fix non-security-critical bugs in 1.4.
If you don’t update your bug, we assume the issue no longer exists and the bug will be closed automatic after 14 days.
eGroupware administrator
linked entries:
http://www.egroupware.org/egroupware/index.php?menuaction=tracker.tracker_ui.edit&tr_id=1679&no_popup=1
