Browser hangs when first logging in ldap auth mode
hi,
EGW 1.6.002 is set with ldap authentification only (local sql data storage )
when an new user try to log in, after filling username and password and press Logging Button , nothing happens, (just the message waiting for myserver_name…in the status bar , the progress bar leave empty)
however, at the same time , on a admin session, if i look at the users accounts , my new user IS there .
on the frozen machine, if i press the red cross (interrupt the loading of the page ) and press the logging button again , it’s OK , I normally acces to the web interface .
After , no more logging problem , all goes fine and quickly
tested on IE 8 and Firefox 3.5
Any ideas ?
Hi Marc,
marc.patouillard schrieb:
hi,
Any ideas ?
Never had that kind of problem.
I would recommend to trace the communication between LDAP and Apache.
[open style of IT]
Morschheimer Strasse 15
67292 Kirchheimbolanden
fon +49 (0) 6352 70629-0
fax +49 (0) 6352 70629-30
mailto: rb@stylite.de
www.stylite.de
www.egroupware.org
Geschäftsführer Andre Keller,
Gudrun Müller, Ralf Becker
ahead of the curve. Join us from November 9-12, 2009. Register now!
http://p.sf.net/sfu/devconf
Hello ralf
I’ve investigated deeper our problem :
EGW 1.6.002 is set with ldap authentification only (local sql data storage)
-the problem : when an NEW user try to log in, after filling username and password and
and press Logging Button , we have a VERY LONG wait (9-10 mn) before getting the welcome screen .
-It only happens at the first connection , when egw creates the new user in the mysql tables .
VERY IMPORTANT , with the 1.6.001 version : ALL IS OK .
Obviously , it’s the upgrade 1.6.001 1.6002 wich is responsible of this problem .
Cheers
if i downgrade phpgwapi/inc/class.hooks.inc.php from rev 27127 to revision 25362 it solves the problem !!
Hi Marc,
I can not believe that’s the real cause.
Looking at the diff
http://svn.stylite.de/viewvc/egroupware/branches/1.6/phpgwapi/inc/class.hooks.inc.php?r1=26424&r2=27127
The only difference is, how the list of applications (to execute a hook
for) is compiled.
Maybe you should check, if you get different application names, each
way. That would be the only explanation.
marc.patouillard wrote:
Hello ralf
storage)
password and
problem .
Cheers
ralfbecker wrote:
Hi Marc,
hi,
storage
of
acces
Any ideas ?
[open style of IT]
www.stylite.de
www.egroupware.org
now!
[open style of IT]
www.stylite.de
www.egroupware.org
I’m sorry , but the fact is, when i downgrade phpgwapi/inc/class.hooks.inc.php from rev 27127 to revision 25362 it solves the problem
I can’t explain why because I don’t know much about egw’s source (maybe some strange side-effect ?) but It works
Ps if I change again 25362 by rev 27127 : The problem go back .
obviously the changes between these 2 versions of this file are at the origin of the problem .
Tested on two differents servers with differents contents of database
cheers
Please report the differences of the returned applications, otherwise we
will not change anything back, as the changes were made for a good reason.
the problem
cheers
ralfbecker wrote:
Hi Marc,
Looking at the diff
for) is compiled.
revision
Hello ralf
storage)
and
password and
problem .
Cheers
ralfbecker wrote:
Hi Marc,
hi,
storage
and
of
acces
Any ideas ?
[open style of IT]
www.stylite.de
www.egroupware.org
your
stay
now!
[open style of IT]
www.stylite.de
www.egroupware.org
now!
[open style of IT]
www.stylite.de
www.egroupware.org
what do you mean by " the differences of the returned applications" ?
thanks
Hi Marc,
The commit you are referencing changes the way a list of applications
get compiled, for which the hook gets called.
This list should be identical in both cases. Having the problem you
describe, suggests they are not. So to be able to fix something, you
have to report the different list of applications.
solves
the problem
cheers
ralfbecker wrote:
Hi Marc,
Looking at the diff
for) is compiled.
revision
Hello ralf
storage)
and
password and
user
this
problem .
Cheers
ralfbecker wrote:
Hi Marc,
hi,
storage
and
for
loading
of
acces
Any ideas ?
[open style of IT]
www.stylite.de
www.egroupware.org
CA
your
stay
now!
[open style of IT]
www.stylite.de
www.egroupware.org
stay
now!
[open style of IT]
www.stylite.de
www.egroupware.org
now!
[open style of IT]
www.stylite.de
www.egroupware.org
how or where can i get theses 2 lists of applications ? I don’t know where to search
thanks
