Allowed memory exhausted
After modifying 10 entries in addressbook I get the following error in log:
[05-May-2009 14:37:28] PHP Fatal error: Allowed memory size of 67108864 bytes exhausted (tried to allocate 785825 bytes) in Unknown on line 0
I can do any further editing after logging out and then in.
If I change the PHP memory_limit option from 64M to 128M, then I can edit 15 entries before it is blocked.
My environment:
  • eGroupware 1.6.001
  • PHP 5.2.0
  • openSuSE 10.2
    Thank you for your answer in advance.
    Regards, Zoltán Németh
It’s most likely a PHP bug. PHP 5.2.9 is out now and the very irritating memory leaks seems to have been resolved.
I had been receiving chronic memory errors since upgrading EGW to 1.6. Then, another web-app started suffering from the same errors.
After doing a google search on PHP and memory leaks, it was discovered PHP has had a running history of this problem.
I had PHP 5.2.3. Now with 5.2.9, everything seems to be peachy.
Cheers,
Don
may be its the Parameter php_value_limit in your .htaccess file.
Herbert
I set the php_value memory_limit but it was not a help.
Thank you.
Zoltán
I think the PHP 5.2.9 might be a help. I am afraid of installing PHP 5.2.9 because the openSuSE updates does not contain it yet.
Regards,
Zoltán
