Neues Ticket erstellt von Daniel Simon am 2009/07/30 20:11
Verfolgungssystem: Bugs
Kategorie: GroupDAV
Version: Version 1.6.001
Status: Offen
Prozent erledigt: 0%
Priorität: 5 - mittlere
Erstellt von: Daniel Simon
Zugewiesen an: Ralf Becker
Zusammenfassung: #2201 - Incorrect german ‘Umlauts’ when using GroupDAV with Lightning or Kontact
When accessing calendars with Thunderbird/Lightning or Kontact via GroupDAV the following problem orrurs:
Events containing german umlauts AND carriage returns are dispayed malformed. Instead of the umlauts something like ‘=C3=B6=C3=A4=C3=BC=0D=0A=C3=96=C3=84=C3=9C=0D=0A=C3=9F=C3=9F=C3=9F’ is diplayed, which are the utf-8 hex-codes of the according umlauts. If the events contain umlauts, but NO carriage returns everything works fine, instead.
In the WebUI or while using iCalSrv umlauts are generally working right.
The origin of the events doesn’t matter, when the mentioned problem occurs. They could have been created using the WebUI, iCal or even CalDAV. There’s no difference.
eGroupware and MySQL-Database are using UTF-8-Encoding.
Tested Versions were:
eGroupware 1.6.001 + 1.6.002
Ubuntu 8.10 Server 64-bit -
Kernel 2.6.27-14-server
Apache2 2.2.9-7ubuntu3.2
PHP 5.2.6-2ubuntu4.2
MySQL 5.0.67-0ubuntu6 -
Ubuntu 8.10 Server 32-bit -
(Same configuration as 64-bit-version above) -
Debian 5.0.2 Lenny 32-bit -
Kernel 2.6.26-2-686
Apache2 2.2.9-10+lenny4
PHP 5.2.6.dfsg.1-1+lenny3
MySQL 5.0.51a-24+lenny1
Clients:
Thunderbird (2.0.0.22 + 2.0.0.21) with Lightning 0.9 (on Ubuntu-Linux 9.04 and Windows 2000 / XP)
Kontact 1.4.2
Linked entries:
http://www.egroupware.org/egroupware/index.php?menuaction=tracker.tracker_ui.edit&tr_id=2201&no_popup=1
