Ticket modified by Jörg Lehrke at 2009/07/18 15:13
Tracking System: Bugs
Category: SyncML
Version: Trunk
Status: Open
Resolution: None
Completed: 0%
Priority: 5 - medium
Created By: camel camel
Assigned to: Jörg Lehrke
Summary: #2171 - SYNCING from EGW to Outlook (recover sync) -> Field problems
ok, here i add the whole logs from funambol, EGW server logs, and pictures of the items from calendar and contact
in contact there is 1 item
in calendar there are 2 items
i made pictures of the items in EGW, and - after sync - also in Outlook
see attached:
what i see:
.) a lot of fileds are complete different and some fields will be deleted or are empty
.) special chars (like quote, carr. return in note of a appointment are strange after syncing
.) birthday apointments are not any more “full day appointment”
(the test are done with apache2, postgresql8, EGW trunk +branch syncml-1.2 version 27451,funambol 8.03, outlook 2007)
i will add logs and pictures later
Comment by Jörg Lehrke at 2009/07/18 15:13:
Here is what I can see from the logs:
The contact vCard entry is RFC conform but Funambol does not like it.
ENCODING=QUOTED-PRINTABLE in not understood properly, although it is used for the other direction (Funambol -> eGW). There is no way to fix this on eGW side. You have to complain at Funambol.
The field matching for this client is now improved in the trunk version. -
The calendar entry is exchanged in SIF format. eGW should import the event “whole day”.
I improved the import part within the trunk version.
Linked entries:
http://www.egroupware.org/egroupware/index.php?menuaction=tracker.tracker_ui.edit&tr_id=2171&no_popup=1
