Ticket modified by Jörg Lehrke at 2009/07/16 00:04
Tracking System: Bugs
Category: SyncML
Version: Trunk
Status: Open
Resolution: None
Completed: 0%
Priority: 5 - medium
Created By: camel camel
Assigned to: Jörg Lehrke
Summary: #2163 - RECOVER SYNC - calendar/contacts - TESTS are not exact the same
hi,
so i test now RECOVER SYNC in detail.
the idea for checking is:
to sync all appointments tofrom outlook to EGW (recover sync delete all old appointments on server or on outlook) - depends on direction.
then i can compare if all appointments are the same or if something is missing.
well i did it: (calendar items 1111)
1.) RECOVER SYNC all appointments from Outlook to EGW
then
2.) backup/copy all appointments in outlook to compare folder "calendar_compare"
3.) RECOVER SYNC all appointments from EGW to Outlook
and it works without an error, but …there are differents
and then i compare the appointments on outlook with the calendar: “calendar_compare”
BUG:
what i see is: (1085 from 1111 are complete the same)
differents are in detail:
1.) all birthdays are different with 1 hour - so they are different to orig.
ex:
outlook orig: Geburtstag von Christian 22.10.1962 00:00
EGW’s sync: Geburtstag von Christian 22.10.1962 01:00
2.) special chars are handled different
ex:
outlook orig: Christbaum richten mit Trinkl’s
EGW’s sync: Christbaum richten mit Trinkl’s
ex:
outlook orig: bei "Freiwilligen Vesicherung"
EGW’s sync: bei “Freiwilligen Vesicherung”
3.) on contacts are did the same and it was looking almost good (excluded the saveas and so it is different)
ex:
outlook orig: saveas: "Wutzlbauer, Hans (Firma X)"
EGW’s sync: saveas: “Herr Hans Wutzlbauer”
some ideas what it can be ?
to 1: 1hr different - time zone ? bug ?
to 2: i have configured UTF8 - bug ?
to 3: i have configured “Name, Surename (Company)” in EGW settings and own sort is also set to this options, and further also set in outlook as default- so why is it different ? bug ?
Comment by Jörg Lehrke at 2009/07/16 00:04:
2. I don’t get the point???
Comment by Jörg Lehrke at 2009/07/16 00:02:
- Don’t store Birthdays within the Outlook Calendar. Outlook does not handle these properly. You will alway end up with a mess due to TZ issues. Keep these dates in you contacts.
Comment by Jörg Lehrke at 2009/07/15 23:59: - is #2160 again
Comment by camel camel at 2009/07/15 23:20:
on bug 3 - i checked the db. in the db the n_fileas there it is the same as it is in outlook.
so for me, it seems to be, that on RECOVER SYNCING FROM EGW TO OL - there is the problem.
i’m testing with the lastest trunk 27449
@ralf
thanks for merging syncml-1.2 to trunk
Comment by camel camel at 1970/01/01 01:33:
on bug 3 - maybe this also belongs to bug: #2160
Linked entries:
http://www.egroupware.org/egroupware/index.php?menuaction=tracker.tracker_ui.edit&tr_id=2163&no_popup=1
