#2131 - [Patch] Integration of phpFreeChat
Ticket modificado por Guilherme Rocha em 2009/12/04 16:30
Sistema de Tickets: Patches
Categoria: Setup
Versão: Version 1.6.002
Status: Fechado
Resolução: Aceito
Completado: 0%
Prioridade: 5 - média
Criado por: Hans-Juergen Tappe
Designado para: Ralf Becker
Resumo: #2131 - [Patch] Integration of phpFreeChat
The attached patch provides integratin of the AJAX based chat application “phpfreechat”.
It uses the remote SVN for integration such that a minimized effort would be introduced for maintenance inside eGw.
The attached zip includes a howto.txt explaining the setup procedure.
The navbar images could require some other image. I have no access to the design resources, I think.
P.S.: Please sort this into any quere and category fitting better…
Comentário feito por Guilherme Rocha em 2009/12/04 16:30:
so folks, where we can download this patch enhanced by Ralf? in what svn branch?
Comentário feito por Raúl Cruz em 2009/10/21 01:00:
Hi, I tried to install the application following the steps but sent me the following error:
phpFreeChat cannot be initialized, please correct these errors:
* 'language' parameter is not valid. Available values are: 'nl_NL, ko_KR, nl_BE, tr_TR, pt_PT, en_US, eo, hr_HR, vi_VN, es_ES, zh_TW, nn_NO, ru_RU, id_ID, hu_HU, th_TH, hy_AM, oc_FR, da_DK, de_DE-formal, uk_RO, nb_NO, fr_FR, it_IT, sv_SE, uk_UA, sr_CS, ar_LB, bg_BG, pt_BR, ba_BA, bn_BD, el_GR, zh_CN, gl_ES, pl_PL, de_DE-informal, ja_JP'
Version API eGroupWare: 1.6.001
Languages:
English (en)
Español (es-es) -> Default
Best Regards.
Languages:
English (en)
Best Regards.
Comentário feito por Ralf Becker em 1970/01/01 01:33:
Hi Hans-Jürgen,
imported your integration - thought I modified it a bit :wink:
Removed a lot unnecessary code.
To update your own installation, you best delete/move away the phpfreechat dirs in the egw-root AND the files directory.
Thanks for contributing to EGroupware :slight_smile:
Linked entries:
http://www.egroupware.org/egroupware/index.php?menuaction=tracker.tracker_ui.edit&tr_id=2131&no_popup=1
Checked the forum
i think i am too new to understand the solution,
can someone please tell me in simple terms how to resolve
this error
using egroupware version:1.8
centos 5
