Ticket modified by Ralf Becker at 2009/04/03 14:34
Tracking System: Bugs
Category: Infolog
Version: Version 1.6.001
Status: Closed
Resolution: Fixed
Completed: 0%
Priority: 7
Created By: Aeliya Grevnyov
Assigned to: Ralf Becker
Summary: #1838 - problem with utf-8 data in all csv imports
when i import csv in infolog (utf8, russian charset), russian words not
importing
importing OK, if only latin or digets
export.csv in Attachments
Comment by Ralf Becker at 2009/04/03 14:34:
This bug is fixed in our subversion repository now.
You can update via subversion with the following commands:
cd /path/to/egroupware
svn update * # mind the */asterisk
To check if you have svn installed try running svn version. To install the svn command under Linux install the package “subversion”. For Windows you can use eg. TortoiseSVN (http://tortoisesvn.tigris.org).
Comment by Aeliya Grevnyov at 2009/04/02 04:52:
Certainly. I selected utf-8
but i test import again in current svn branch 1.6 and it work correctly
this problem fixed!
Later i can test this in other company
Comment by Ralf Becker at 2009/04/01 22:52:
Have you selected utf-8 as charset in the import dialog?
Linked entries:
http://www.egroupware.org/egroupware/index.php?menuaction=tracker.tracker_ui.edit&tr_id=1838&no_popup=1
