Hey nathan,
thanks for help… I got it working now. there was a problem with a
sql
table.
I reinstalled the whole database adn now it works.
this time I took your egw+perp-package.
Glad to hear it, I was just about to follow up this morning.
Do you know which table?
Nathan Gray
nathan at goarctic dot com
Open Source Business Conference (OSBC), March 24-25, 2009, San Francisco, CA
-OSBC tackles the biggest issue in open source: Open Sourcing the Enterprise
-Strategies to boost innovation and cut costs with open source participation
-Receive a $600 discount off the registration fee with the source code: SFAD http://p.sf.net/sfu/XcvMzF8H
I still not able to read the errors g
but here’s the error appears:
Database error
Invalid SQL: SELECT perp_work_order_detail.work_order_id,perp_work_order_detail.detail_id,perp_work_order_detail.stock_id,perp_work_order_detail.quantity,perp_work_order_detail.direct_cost,perp_work_order_detail.indirect_cost,option_search,perp_work_order_bill_of_material.bill_of_material_id FROM perp_work_order_detail JOIN perp_bill_of_material ON
perp_bill_of_material.stock_id = perp_work_order_detail.stock_id
JOIN perp_work_order_bill_of_material ON
perp_bill_of_material.bill_of_material_id = perp_bill_of_material.bill_of_material_id AND
perp_work_order_bill_of_material.work_order_id = perp_work_order_detail.work_order_id AND
perp_work_order_bill_of_material.detail_id = perp_work_order_detail.detail_id WHERE perp_work_order_detail.work_order_id = AND perp_work_order_detail.detail_id = :
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘AND perp_work_order_detail.detail_id =’ at line 6
perhaps it helps you…
I’m using pERP in a 20 user company with focus service and small manufacturing.
until now it seems to be a good decision.
Thanks for it smile
corresponds to
It does, thank you. Looks like something went wrong earlier in the
process, and it just carried through.
manufacturing.
Thanks for it smile
Until now? I thought this particular error had been resolved by re-
installing the database, and you had it working now.
I’m particularly interested in following your experience setting up
and using pERP, as there are relatively few manufacturers testing
pERP. I have many questions for you (later).
Nathan Gray
